x-apigateway-backend.httpVpcEndpoints
Meaning: HTTP VPC backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      parameters:
        - name: "X-Auth-Token"
          description: "Authentication token"
          type: "string"
          in: "header"
          required: true
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "HTTP-VPC"
        httpVpcEndpoints:
          scheme: "http"
          method: "GET"
          path: "/users"
          timeout: 30000
       Parameter  |
       Mandatory  |
       Type  |
       Description  |
       name  |
       Yes  |
       Array  |
       VPC channel name.  |
       scheme  |
       Yes  |
       String  |
       Backend request protocol. HTTP and HTTPS are supported.  |
       method  |
       Yes  |
       String  |
       Backend request method. The options include GET, POST, PUT, DELETE, HEAD, OPTIONS, PATCH, and ANY.  |
       path  |
       Yes  |
       String  |
       Backend request path, which can contain variables.  |
       timeout  |
       No  |
       Number  |
       Backend request timeout in milliseconds. The range is 1–60,000, and the default value is 5000.  |
