Error Codes
The following table lists the error codes that you may encounter when calling APIs. If an error code starting with APIGW is returned after you call an API, rectify the fault by referring to the instructions provided in section "Error Codes" in the API Request Signing Guide.
  - For details about the error codes that may occur when you manage APIs, see section "Error Codes" in the API Gateway API Reference.
 - If an error occurs when you use APIG, find the error message and description in the following table according to the error code, for example, APIG.0101. The error messages are subject to change without prior notice.
       Error Code  |
       Error Message  |
       HTTP Status Code  |
       Description  |
       Solution  |
       APIG.0101  |
       The API does not exist or has not been published in the environment.  |
       404  |
       Check whether the domain name, method, and path are consistent with those of the created API. Check whether the API has been published. If it has been published in a non-production environment, check whether the X-Stage header in the request is the environment name. Check whether the domain name used to call the API has been bound to the group to which the API belongs.  |
       APIG.0101  |
       The API does not exist.  |
       404  |
       The API request method does not exist.  |
       Check whether the API request method is the same as the method defined by the API.  |
       APIG.0103  |
       The backend does not exist.  |
       500  |
       The backend service was not found.  |
       Contact technical support.  |
       APIG.0104  |
       The plug-ins do not exist.  |
       500  |
       No plug-in configurations were found.  |
       APIG.0105  |
       The backend configurations do not exist.  |
       500  |
       No backend configurations were found.  |
       APIG.0106  |
       Orchestration error.  |
       400  |
       An orchestration error occurred.  |
       Check whether the frontend and backend parameters of the API are correct.  |
       APIG.0107  |
       The custom lua script encountered an unexpected error  |
       500  |
       An unknown error occurred in the Lua script.  |
       APIG.0201  |
       API request error.  |
       400  |
       Invalid request parameters.  |
       Set valid request parameters.  |
       APIG.0201  |
       Request entity too large.  |
       413  |
       The request body exceeds 12 MB.  |
       Reduce the size of the request body.  |
       APIG.0201  |
       Request URI too large.  |
       414  |
       The request URI exceeds 32 KB.  |
       Reduce the size of the request URI.  |
       APIG.0201  |
       Request headers too large.  |
       494  |
       The request headers are too large because one of them exceeds 32 KB or the total length exceeds 128 KB.  |
       Reduce the size of the request headers.  |
       APIG.0201  |
       Backend unavailable.  |
       502  |
       The backend service is unavailable.  |
       Check whether the backend address configured for the API is accessible.  |
       APIG.0201  |
       Backend timeout.  |
       504  |
       The backend service has timed out.  |
       Increase the timeout duration of the backend service or shorten the processing time.  |
       APIG.0201  |
       An unexpected error occurred  |
       500  |
       An internal error occurred.  |
       APIG.0202  |
       Backend unavailable  |
       502  |
       The backend is unavailable.  |
       Check whether the backend request protocol configured for the API is the same as the request protocol used by the backend service.  |
       APIG.0203  |
       Backend timeout  |
       504  |
       APIG.0204  |
       SSL protocol is not supported: TLSv1.1  |
       400  |
       The SSL protocol version is not supported.  |
       Use a supported SSL protocol version.  |
       APIG.0205  |
       Verify client certificate failed  |
       400  |
       Failed to verify the client certificate.  |
       Check whether the client certificate is correct.  |
       APIG.0301  |
       Incorrect IAM authentication information.  |
       401  |
       The IAM authentication details are incorrect.  |
       Check whether the token is correct.  |
       APIG.0302  |
       The IAM user is not authorized to access the API.  |
       403  |
       The IAM user is not allowed to access the API.  |
       Check whether the user is controlled by a blacklist or whitelist.  |
       APIG.0303  |
       Incorrect app authentication information.  |
       401  |
       The app authentication details are incorrect.  |
       Check whether the request method, path, query strings, and request body are consistent with those used for signing; check whether the date and time on the client are correct; and check whether the signing code is correct by referring to section "Calling APIs Through App Authentication" of the Developer Guide.  |
       APIG.0304  |
       The app is not authorized to access the API.  |
       403  |
       The app is not allowed to access the API.  |
       Check whether the app has been authorized to access the API.  |
       APIG.0305  |
       Incorrect authentication information.  |
       401  |
       The authentication information is incorrect.  |
       Check whether the authentication information is correct.  |
       APIG.0306  |
       API access denied.  |
       403  |
       Access to the API is not allowed.  |
       Check whether you have been authorized to access the API.  |
       APIG.0307  |
       The token must be updated.  |
       401  |
       The token needs to be updated.  |
       Obtain a new token from IAM.  |
       APIG.0308  |
       The throttling threshold has been reached.  |
       429  |
       Try again after the throttling resumes. If the number of debugging domain requests per day is reached, bind an independent domain name to the service to which the API belongs.  |
       APIG.0310  |
       The project is unavailable.  |
       403  |
       The project is currently unavailable.  |
       Select another project and try again.  |
       APIG.0311  |
       Incorrect debugging authentication information.  |
       401  |
       The debugging authentication details are incorrect.  |
       APIG.0312  |
       Incorrect third-party authentication information,auth fail  |
       401  |
       The authentication failed because the third-party authentication information is incorrect.  |
       Check whether the identity information is correct.  |
       APIG.0313  |
       Incorrect third-party authentication information,identities error  |
       401  |
       The identity included in the third-party authentication information is incorrect.  |
       Check whether the identity information is consistent with the identity source in the third-party authentication plug-in.  |
       APIG.0314  |
       Incorrect third-party authentication information,access deny  |
       403  |
       Access denied because the third-party authentication information is incorrect.  |
       Contact technical support to check whether the request is a service request. If yes, increase the brute force threshold of the third-party authentication plug-in.  |
       APIG.0401  |
       Unknown client IP address.  |
       403  |
       The client IP address cannot be identified.  |
       APIG.0402  |
       The IP address is not authorized to access the API.  |
       403  |
       The IP address is not allowed to access the API.  |
       Check whether the IP address is controlled by a blacklist or whitelist.  |
       APIG.0404  |
       Access to the backend IP address has been denied.  |
       403  |
       The backend IP address cannot be accessed.  |
       Check whether the backend IP address or the IP address corresponding to the backend domain name is accessible.  |
       APIG.0405  |
       The app is not accessed from a trusted IP address.  |
       403  |
       The application is not accessed from a trusted IP address.  |
       Check whether the source IP address is allowed or denied in the access control policy.  |
       APIG.0501  |
       The app quota has been used up.  |
       405  |
       The app quota has been reached.  |
       Increase the app quota.  |
       APIG.0502  |
       The app has been frozen.  |
       405  |
       Check whether your account balance is sufficient.  |
       APIG.0601  |
       Internal server error.  |
       500  |
       APIG.0602  |
       Bad request.  |
       400  |
       Invalid request.  |
       Check whether the request is valid.  |
       APIG.0605  |
       Domain name resolution failed.  |
       500  |
       Check whether the domain name is correct and has been bound to a correct backend address.  |
       APIG.0606  |
       Failed to load the API configurations.  |
       500  |
       API configurations could not be loaded.  |
       APIG.0607  |
       The following protocol is supported: {xxx}  |
       400  |
       The protocol is not supported. Only xxx is supported. xxx is subject to the actual value in the response.  |
       Use HTTP or HTTPS to access the API.  |
       APIG.0608  |
       Failed to obtain the admin token.  |
       500  |
       The administrator account details cannot be obtained.  |
       APIG.0609  |
       The VPC backend does not exist.  |
       500  |
       The workload backend service cannot be found.  |
       APIG.0610  |
       No backend available.  |
       502  |
       No backend services are available.  |
       Check whether all backend services are available. For example, check whether the API calling information is consistent with the actual configuration.  |
       APIG.0611  |
       The backend port does not exist.  |
       500  |
       The backend port was not found.  |
       APIG.0612  |
       An API cannot call itself.  |
       500  |
       Modify the backend configurations, and ensure that the number of layers the API is recursively called does not exceed 10.  |
       APIG.0613  |
       The IAM service is currently unavailable.  |
       503  |
       IAM is currently unavailable.  |
       APIG.0615  |
       Incorrect third-party authentication VPC information  |
       500  |
       Failed to obtain the load balance channel nodes for third-party authentication.  |
       Check whether the load balance channel for third-party authentication is correctly configured.  |
       APIG.0616  |
       Incorrect third-party authentication request information  |
       500  |
       Failed to connect to the third-party authentication service.  |
       Check whether the third-party authentication service is normal.  |
       APIG.0617  |
       Incorrect third-party authentication response information  |
       500  |
       Failed to obtain response from the third-party authentication service.  |
       APIG.0705  |
       Backend signature calculation failed.  |
       500  |
       APIG.0802  |
       The IAM user is forbidden in the currently selected region  |
       403  |
       The IAM user is disabled in the current region.  |
       APIG.2102  |
       PublicKey is null  |
       400  |
       The signature key is not found.  |
       APIG.2201  |
       Appkey or SecretKey is invalid  |
       400  |
       Invalid AppKey or SecretKey.  |
       Check whether the AppKey and SecretKey in the request are correct.  |
       APIG.2202  |
       Refresh token is invalid  |
       400  |
       Invalid refresh token.  |
       Check whether the refresh token is correct.  |
       APIG.2203  |
       Access token is invalid  |
       400  |
       Invalid access token.  |
       Check whether the access token is correct.  |
       APIG.2204  |
       ContentType invalid  |
       400  |
       Invalid ContentType.  |
       Check whether the ContentType is correct.  |
       APIG.2205  |
       Auth parameter invalid  |
       400  |
       Invalid authentication parameter.  |
       Check whether the authentication parameters are correct.  |
       APIG.2206  |
       Auth method invalid  |
       400  |
       Invalid authentication mode.  |
       Check whether the authentication mode is correct.  |
       APIG.2208  |
       The length of through_data is out of range  |
       400  |
       The length of through_data is out of range.  |
       The maximum length of through_data is 300. Adjust through_data based on the actual situation.  |
       APIG.2209  |
       The value of grant_type is not in enum List  |
       400  |
       The value of grant_type is invalid.  |
       The value of grant_type can only be client_credentials or refresh_token. Change it based on the actual situation.  |
       APIG.2210  |
       Lack of grant_type  |
       400  |
       The authorization type is missing.  |
       Add grant_type.  |
       APIG.2211  |
       Lack of client_id  |
       400  |
       The client ID is missing.  |
       Add a client ID.  |
       APIG.2212  |
       Lack of client_secret  |
       400  |
       The client secret is missing.  |
       Add a client secret.  |
       APIG.2213  |
       Lack of refresh_token  |
       400  |
       The refresh token is missing.  |
       APIG.1001  |
       Refresh token is expired  |
       401  |
       The refresh token has expired.  |
       Obtain another refresh token.  |
       APIG.1002  |
       Access token is expired  |
       401  |
       The access token has expired.  |
       Obtain another access token.  |
       APIG.1003  |
       App not match refresh token  |
       401  |
       The app does not match the refresh token.  |
       Check whether the client_id is correct.  |
       APIG.1004  |
       App not exist  |
       401  |
       The app does not exist.  |
       APIG.1009  |
       AppKey or AppSecret is invalid  |
       400  |
       The AppKey or AppSecret is invalid.  |
       Check whether the AppKey or AppSecret in the request is correct.  |
