Authorizing API Access
APIs using app authentication can only be called by credentials that have been authorized to call them.
  - You can authorize credentials only to call APIs that use app authentication.
 - A credential can be authorized to access a maximum of 1000 APIs.
- You have published an API.
 - You have created an environment.
 - You have created a credential.
- Go to the APIG console.
 - Select a dedicated gateway at the top of the navigation pane.
- Choose API Management > API Groups.
 - Click a group name.
 - On the APIs tab, select the target API and choose More > Authorize Credentials.
 - Click Select Credentials.
 - Select an environment, search for and select desired credentials, and click OK. The authorized credentials are displayed on the Authorize Credentials page.
To cancel the authorization of a credential, click Cancel Authorization in the Operation column that contains the credential.
Follow-Up Operations
After you authorize a credential for an API, the API can be called by the credential using SDKs of different programming languages.
