On this page
Help Center/ Anti-DDoS/ User Guide (Kuala Lumpur Region)/ Viewing a Public IP Address
Updated on 2024-02-22 GMT+08:00
This topic describes how to view a public IP address.
NOTICE:
  • Anti-DDoS automatically enables the protection by default.
  • You are not allowed to disable Anti-DDoS after it has been enabled.
  • You have obtained a username and password for logging in to the management console.
  2. Click in the upper left corner of the management console and select the region and project.
  3. Click . Under Security, choose Anti-DDoS.
  4. On the Public IP Addresses tab, view all protected public IP addresses. Table 1 describes the parameters.
    • Click Enable Anti-DDoS for All IP Addresses to enable the protection for all unprotected IP addresses in the current region.
    • After the default Anti-DDoS protection settings are enabled, traffic is scrubbed when its volume reaches 120 Mbit/s. You can modify Anti-DDoS protection settings according to Configuring an Anti-DDoS Protection Policy.
    • Anti-DDoS provides a 300 Mbit/s mitigation capacity against DDoS attacks. Traffic from the attacked public IP address will be routed to the black hole.
    • The All statuses drop-down box enables you to specify a status so that only public IP addresses of the selected status are displayed.
    • Enter a public IP address or a keyword of a public IP address in the search box and click or to search for the desired public IP address.
    Table 1 Parameter description
    Public IP Address
    Public IP address protected by Anti-DDoS
    If Anti-DDoS is enabled for a public IP address, you can click the IP address to go to its Monitoring Report page.
    Protection Status
    Protection status of a public IP address. The values are:
    • Normal
    • Configuring
    • Disabled
    • Cleaning
    • Black hole
