to_char
Updated on 2025-01-22 GMT+08:00
This function is used to convert a date into a string in a specified format.
Syntax
to_char(string date, string format)
Parameters
Table 1 Parameters
Mandatory
Type
date
Yes
DATE
or
STRING
Date that needs to be processed
The following formats are supported:
  • yyyy-mm-dd
  • yyyy-mm-dd hh:mi:ss
  • yyyy-mm-dd hh:mi:ss.ff3
format
Yes
STRING
Format of the date to be converted
Constant of the STRING type. Extended date formats are not supported.
The value is a combination of the time unit (year, month, day, hour, minute, and second) and any character.
  • yyyy indicates the year.
  • mm indicates the month.
  • dd indicates the day.
  • hh indicates the hour.
  • mi indicates the minute.
  • ss indicates the second.
Return Values
The return value is of the STRING type.
  • If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
  • If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
  • If the value of format is NULL, NULL is returned.
Example Code
The static data 2023-08*16 is returned.
select to_char('2023-08-16 10:54:36','Example static data yyyy-mm*dd');
The value 20230816 is returned.
select to_char('2023-08-16 10:54:36', 'yyyymmdd');
The value NULL is returned.
select to_char('Example static data 2023-08-16','Example static data yyyy-mm*dd');
select to_char('20230816', 'yyyy');
select to_char('2023-08-16 10:54:36', null);
