reverse
This function is used to return a string in reverse order.
Syntax
reverse(string <str>)
Parameters
Parameter |
Mandatory |
Type |
Description |
str |
Yes |
STRING |
If the value is of the BIGINT, DOUBLE, DECIMAL, or DATETIME type, the value is implicitly converted to the STRING type for calculation. |
Return Values
The return value is of the STRING type.
- If the value of str is not of the STRING, BIGINT, DOUBLE, DECIMAL, or DATETIME type, an error is reported.
- If the value of str is NULL, NULL is returned.
Example Code
The value LQS krapS is returned.
SELECT reverse('Spark SQL');
The value [3,4,1,2] is returned.
SELECT reverse(array(2, 1, 4, 3));
