regexp_instr
Updated on 2025-01-22 GMT+08:00
This function is used to return the start or end position of the substring that matches a specified pattern for the occurrence time, starting from start_position in the string source.
Syntax
regexp_instr(string <source>, string <pattern>[,bigint <start_position>[, bigint <occurrence>[, bigint <return_option>]]])
Parameters
Table 1 Parameters
Mandatory
Type
source
Yes
STRING
Source string
pattern
Yes
STRING
Constant or regular expression of the STRING type. Pattern to be matched. If the value of this parameter is an empty string, an error is reported.
start_position
No
BIGINT
Constant of the BIGINT type. Start position of the search. If it is not specified, the default value 1 is used.
occurrence
No
BIGINT
Constant of the BIGINT type. It indicates the specified number of matching times. If this parameter is not specified, the default value 1 is used, indicating that the first occurrence position is searched.
return_option
No
BIGINT
Constant of the BIGINT type. This parameter indicates the location to be returned. The value can be 0 or 1. If this parameter is not specified, the default value 0 is used. If this parameter is set to a value of another type or a value that is not allowed, an error message is returned. The value 0 indicates that the start position of the match is returned, and the value 1 indicates that the end position of the match is returned.
Return Values
The return value is of the BIGINT type. return_option indicates the start or end position of the matched substring in source.
  • If the value of pattern is an empty string, an error is reported.
  • If the value of start_position or occurrence is not of the BIGINT type or is less than or equal to 0, an error is reported.
  • If the value of source, pattern, start_position, occurrence, or return_option is NULL, NULL is returned.
Example Code
The value 6 is returned.
select regexp_instr('a1b2c3d4', '[0-9]', 3, 2);
The value NULL is returned.
select regexp_instr('a1b2c3d4', null, 3, 2);
