lower/lcase
Updated on 2025-01-22 GMT+08:00
This function is used to convert all characters of a string to the lower case.
Syntax
lower(string A) / lcase(string A)
Parameters
Table 1 Parameter
Mandatory
Type
A
Yes
STRING
Text string to be converted
Return Values
The return value is of the STRING type.
  • If the value of the input parameter is not of the STRING, BIGINT, DOUBLE, DECIMAL, or DATETIME type, an error is reported.
  • If the value of the input parameter is NULL, NULL is returned.
Example Code
Converts uppercase characters in a string to the lower case. An example command is as follows:
The value abc is returned.
select lower('ABC');
The value of the input parameter is NULL. An example command is as follows:
The value NULL is returned.
select lower(null);
