Updated on 2025-01-22 GMT+08:00
ln
This function is used to return the natural logarithm of a given value.
Syntax
ln(DOUBLE a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type.
  • If the value of a is negative or 0, NULL is returned.
  • If the value of a is NULL, NULL is returned.
Example Code
The value 1.144729868791239 is returned.
select ln(3.1415926);
The value 1 is returned.
select ln(2.718281828459045);
The value NULL is returned.
select ln(null);
