decode1
This function is used to implement if-then-else branch selection.
Syntax
decode1(<expression>, <search>, <result>[, <search>, <result>]...[, <default>])
Parameters
Parameter |
Mandatory |
Type |
Description |
expression |
Yes |
All data types |
Expression to be compared |
search |
Yes |
Same as that of expression |
Search item to be compared with expression |
result |
Yes |
All data types |
Return value when the values of search and expression match |
default |
No |
Same as that of result |
If all search items do not match, the value of this parameter is returned. If no search item is specified, NULL is returned. |
Return Values
result and default are return values. These values can be of any data type.
- If they match, the value of result is returned.
- If no match is found, the value of default is returned.
- If default is not specified, NULL is returned.
- If the search options are duplicate and matched, the first value is returned.
Example Code
CREATE EXTERNAL TABLE salary ( dept_id STRING, -- Department userid string, -- Employee ID sal INT ) ROW FORMAT DELIMITED FIELDS TERMINATED BY ',' stored as textfile;
Adds the following data:
d1,user1,1000 d1,user2,2000 d1,user3,3000 d2,user4,4000 d2,user5,5000
Example
Returns the name of each department.
If dept_id is set to d1, DLI is returned. If it is set to d2, MRS is returned. In other scenarios, Others is returned.
select dept, decode1(dept, 'd1', 'DLI', 'd2', 'MRS', 'Others') as result from sale_detail;
Returned result:
d1 DLI d2 MRS d3 Others d4 Others d5 Others
