dateadd
Updated on 2025-01-22 GMT+08:00
This function is used to change a date based on datepart and delta.
To obtain the date with a specified change range based on the current date, use this function together with the current_date or getdate function.
Syntax
dateadd(string date, bigint delta, string datepart)
Parameters
Table 1 Parameters
Mandatory
Type
date
Yes
DATE
or
STRING
Start date
The following formats are supported:
  • yyyy-mm-dd
  • yyyy-mm-dd hh:mi:ss
  • yyyy-mm-dd hh:mi:ss.ff3
delta
Yes
BIGINT
Amplitude, based on which the date is modified
datepart
Yes
BIGINT
Unit, based on which the date is modified
This parameter supports the following extended date formats: year, month or mon, day, and hour.
  • yyyy indicates the year.
  • MM indicates the month.
  • dd indicates the day.
  • hh indicates the hour.
  • mi indicates the minute.
  • ss indicates the second.
Return Values
The return value is of the STRING type.
  • If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
  • If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
  • If the value of date is NULL, NULL is returned.
  • If the value of delta or datepart is NULL, NULL is returned.
Example Code
The value 2023-08-15 17:00:00 is returned after one day is added.
select dateadd( '2023-08-14 17:00:00', 1, 'dd');
The value 2025-04-14 17:00:00 is returned after 20 months are added.
select dateadd('2023-08-14 17:00:00', 20, 'mm');
The value 2023-09-14 17:00:00 is returned.
select dateadd('2023-08-14 17:00:00', 1, 'mm');
The value 2023-09-14 is returned.
select dateadd('2023-08-14', 1, 'mm');
If the current time is 2023-08-14 17:00:00, 2023-08-13 17:00:00 is returned.
select dateadd(getdate(),-1,'dd');
The value NULL is returned.
select dateadd(date '2023-08-14', 1, null);
