- What's New
- Function Overview
- Product Bulletin
Billing
- Billing Overview
- Billing Modes
- Billed Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- How Is CBR Billed?
- What Is the Billing Cycle of Pay-per-Use Vaults?
- How Do I Disable CBR?
- How Do I Unsubscribe from CSBS or VBS Resource Packages?
- Why Is a Message Displayed Indicating Insufficient User Rights When I Create a Policy?
- What Can I do If a Yearly/Monthly-Billed Vault Is About to Expire?
- How Do I Unsubscribe from a Vault?
- What Should I Do If the Fee Is Too High When I Expand the Capacity of a Vault?
- Why Are CBR Backups Displayed on the VBS Console?
- How Do I Purchase a CBR Replication Traffic Package?
- What Resources Do I Need to Implement Cross-Region Backup Replication?
- Why AM I Still Being Billed After a Resource is Deleted?
- Getting Started
User Guide
- Management permissions
Vault Management
- Overview
- Viewing a Vault
- Deleting a Vault
- Associating Resources to a Vault
- Dissociating Resources from a Vault
- Migrating Resources from a Vault
- Expanding Vault Capacity
- Reducing Vault Capacity
- Changing from Pay-per-Use to Yearly/Monthly
- Changing Vault Specifications
- Replicating a Vault Across Regions
- Managing Vault Tags
- Managing the Enterprise Projects of Vaults
- Enabling Backup Locking
- Backup Management
- Policy Management
- Organizational Policy Management
- Application-Consistent Backup
- File Backup (Supported Conditionally)
Restoring Data
- Restoring from a Cloud Server Backup
- Creating an Image from a Cloud Server Backup
- Restoring from a Cloud Disk Backup
- Creating a Disk from a Cloud Disk Backup
- Creating a File System from an SFS Turbo Backup
- Restoring from a Desktop Backup
- Restoring from a File Backup
- Restoring from a Hybrid Cloud Backup
- (Optional) Migrating Resources from CSBS/VBS
- Managing Tasks
- Cloud Eye Monitoring
- Recording CBR Operations Using CTS
- Quotas
- Appendix
Hybrid Cloud Backup Feature Guide
- Hybrid Cloud Backup
- Application Scenarios
- Constraints and Limitations
VMware Backup
- VMware Backup Process
- Downloading and Installing eBackup
- Configuring eBackup
- Adding a VMware Protected Environment
- Preparing for VMware Backup Storage
- Performing VMware Backup
- Restoring Data Using VMware Backups
- Managing a Protected VMware Environment
- Managing VMware Backup Storage
- Managing VMware Backups
- Common Operations
Best Practices
Using a Custom Script to Implement Application-Consistent Backup
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Verifying the Application-Consistent Backup Result
- Protecting SQL Server
- Troubleshooting a Custom Script Error
- Performing Periodic Recovery Drills Using the Backup Data
- Creating Backup Policies Based on Service Tiering
API Reference
- Before You Start
- API Overview
- Calling APIs
CBR APIs
- Tasks
- Protection
- Backups
- Backup Sharing
Vaults
- Creating a Vault
- Querying a Specified Vault
- Querying the Vault List
- Modifying a Vault
- Deleting a Vault
- Applying a Policy to a Vault
- Removing a Policy from a Vault
- Querying the Vault List in Other Regions
- Batch Modifying Vaults
- Setting Auto Backup for a Vault
- Creating a Yearly/Monthly Vault
- Querying Vault Usage of a Project
- File Backup
- Tags
- Policies
- Organizational Policies
- Metering
- Operations
- Restore Points
- Projects
- Application Cases
- Appendix
- SDK Reference
Troubleshooting
- Failed to Execute a Backup Task
- Failed to Delete a Backup
- Failed to Expand the Vault Capacity
- Failed to Attach Disks
- Data Disks Are Not Displayed After a Windows Server Is Restored
- Failed to Cancel Backup Sharing
- Failed to Download or Install the Agent Required by Application-Consistent
- Failed to Install the Agent on Windows
- Failed to Implement Application-Consistent Backup
- A Server Created Using an Image Enters Maintenance Mode After Login
- Failed to Migrate VMware Backups to the Cloud
- Failed to Restore a VMware Backup to a Cloud Server
- An Error Message Is Displayed Indicating that the Path of a Storage Unit Is Invalid
- Failed to Import an eBackup Image Template, with an Error Displayed Indicating That the File Is Invalid
- The Download Dialog Box Disappears When I Download eBackup on a VMware VM
- File Backup Failed Due to Inconsistent Time Between Backup Client and UTC Time
- Concepts
Billing
- Can I Change a Server Backup Vault to a Disk Backup Vault or the Other Way Around?
- What Charges Will I Incur When Using a Backup to Create an Image?
Backup
- Do I Need to Stop the Server Before Performing a Backup?
- Can I Back Up a Server Deployed with Databases?
- How Can I Distinguish Automatic Backups From Manual Backups?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CBR Support Cross-Region Backup?
- How Do I Migrate Server Data Across Regions Using Server Backups?
- Can I Back Up Two Disks to One Target Disk?
- How Do I Replicate a Disk to the Same AZ in a Region as the Source Disk?
- Can I Migrate Backups Between Vaults?
- Can I Use Its Backup for Restoration After a Resource Is Deleted?
- How Many Backups Can I Create for a Resource?
- Can I Use an Incremental Backup to Restore Data After a Full Backup Is Deleted?
- Can I Stop an Ongoing Backup Task?
- How Do I Reduce the Vault Space Occupied by Backups?
- How Do I View the Size of Each Backup?
- How Do I View My Backup Data?
- How Long Will My Backups Be Kept?
- How Do I Implement Periodic Full Backups for My Resources?
- How Do I Query Resources that Have not Been Backed Up?
- Is There Any Requirement on the Network Bandwidth During Data Backup?
Capacity
- How Large of a Vault Do I Need?
- Why Is My Backup Size Larger Than My Disk Size?
- What Can I Do If the Vault Capacity Is Not Enough?
- Why Does the Used Capacity of a Vault Change Only Slightly After I Deleted Unwanted Backups?
- Will Backup Continue If the Usage of a Vault Reaches the Upper Limit?
- How Do I Adjust the Vault Capacity Alarm Threshold?
Restoration
- Do I Need to Stop the Server Before Restoring Data Using Backups?
- Can I Use a System Disk Backup to Recover an ECS?
- Do I Need to Stop the Server Before Restoring Data Using Disk Backups?
- Can a Server Be Restored Using Its Backups After It Is Changed?
- Can a Disk Be Restored Using Its Backups After Its Capacity Is Expanded?
- What Can I Do if the Password Becomes a Random One After I Use a Backup to Restore a Server or Use an Image to Create a Server?
- What Changes Will Be Made to the Original Backup When I Use the Backup to Restore a Server?
- How Do I Restore Data to a New Server?
- How Do I Restore a Data Disk Backup to a System Disk?
- Can I Use CBR to Restore Data to Any Point When the Data Was Backed Up?
- Can I Stop an Ongoing Restoration Task?
Policies
- How Do I Configure Automatic Backup for a Server or Disk?
- Why the New Retention Rule I Changed Is Not Applied?
- How Do I Back Up Multiple Resources at a Time?
- How Do I Retain My Backups Permanently?
- How Can I Cancel Auto Backup or Auto Replication?
- How Can I Have the System Automatically Delete Backups That I No Longer Need?
- Why Aren't My Backups Deleted Based on the Retention Rule?
- Optimization
- Is There a Quota for CBR Vaults?
- Can I Merge My Vaults?
- How Do I Delete a Backup That Has Been Used to Create an Image While Retaining the Image?
- Can I Export Disk Backup Data to Another Server?
- Why Do I Need a Vault to Accept the Image Shared to Me?
- Can I Download Backup Data to a Local PC?
- How Do I Copy Disk Data to Another Account?
- Videos
More Documents
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
- Billing
Backup
- Will the Server Performance Be Affected If I Delete Its Backups?
- Capacity
Restoration
Policies
- How Can I Cancel Auto Backup?
- Optimization
- Troubleshooting Cases
- Appendix
- API Reference (ME-Abu Dhabi Region)
Best Practices (ME-Abu Dhabi Region)
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
User Guide (Paris)
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Auditing
- Quotas
- Concepts
Backup
- Capacity
Restoration
Policies
- Optimization
- Appendix
- API Reference (Paris)
Best Practices (Paris)
- Change History
- Getting Started
- Permissions Management
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
Backup
Restoration
- Policies
- Others
- Appendix
- API Reference (Kuala Lumpur Region)
Best Practices (Kuala Lumpur Region)
- Change History
User Guide (Ankara Region)
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
Backup
- Capacity
Restoration
- Policies
- Others
- Appendix
- API Reference (Ankara Region)
Best Practices (Ankara Region)
- Change History
- Glossary
On this page
Show all
Help Center/
Cloud Backup and Recovery/
Best Practices (Kuala Lumpur Region)/
Using a Custom Script to Implement Application-Consistent Backup/
Using a Custom Script to Implement Consistent Backup for Other Linux Applications/
Compiling an Unfreezing Script
Example unfreezing script named appexample_unfreeze.sh:
#!/bin/sh AGENT_ROOT_PATH=$1 #The root directory required when the Agent invokes the script. Functions, such as log functions, will use this variable. Do not rename this directory. PID=$2 #The PID required when the Agent invokes the script. It is used for command output and do not rename it. . "${AGENT_ROOT_PATH}/bin/agent_func.sh"#Reference script framework, which provides functions, such as logging, encryption, and decryption #Result processing function, which writes operation results into given files for invokers to obtain return values. # Input parameter. $1: 0 indicates a success; 1 indicates a failure. # No return value #RESULT_FILE is defined in agent_func.sh. function ExitWithResult() { Log "[INFO]:Freeze result is $1." echo $1 > ${RESULT_FILE} chmod 666 ${RESULT_FILE} exit $1 } function Main() { Log "*********************************************************************" Log "[INFO]:Begin to freeze appexample." #Check whether appexample exists. If not, 0 is returned and the script exits. #In the process of unfreezing I/Os, the Agent program invokes each unfreezing script in sequence. If any script fails to be invoked, the whole process fails. To avoid interference from other programs, 0 should be returned when appexample cannot be found. which appexample if [ $? -ne 0 ] then Log "[INFO]:appexample is not installed." ExitWithResult 0 fi #Invoke the actual unfreezing command. appexample -unfreeze if [ $? -ne 0 ] then Log "[INFO]:appexample freeze failed." #Unfreezing failed. Record the result and exit. ExitWithResult 1 fi Log "[INFO]:Freeze appexample. success" #Unfreezing successful. Record the result and exit. ExitWithResult 0 } Main
