- User Guide
- Best Practices
- FAQs
On this page
Show all
Help Center/
Managed Threat Detection/
FAQs/
Purchase Consulting/
Will I Be Charged If I Disable All Log Data Sources After Purchasing MTD?
You have paid for the package when purchasing the MTD service. After you disable all log data sources, you will not be charged.
After you purchase a package, additional charges will only be applied when the capacity of the detected log data source exceeds the purchased package capacity.
Parent topic: Purchase Consulting
