Help Center/ Elastic Volume Service/ Help Panel/ EVS Usage Guidelines/ Expanding Capacity of an EVS Disk
Updated on 2025-07-08 GMT+08:00
If your disk space is insufficient, you can increase the disk size by expanding capacity. The disk capacity can only be expanded, not reduced.
Step 1: Expand the disk capacity on the console
Step 2: Log in to the server and extend the partition and file system
