Help Center/
      Virtual Private Cloud/
         User Guide (Paris Regions) /
        Access Control/
        Security Group/
        Managing a Security Group/
      Modifying a Security Group
        Updated on 2024-03-05 GMT+08:00
After a security group is created, you can change its name and description.
 - Click
 in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
 - In the navigation pane on the left, choose Access Control > Security Groups.
The security group list is displayed.
 - Locate the row that contains the security group, click More in the Operation column, and click Modify.
The Modify Security Group dialog box is displayed.
 - Modify the name and description of the security group as required.
 - Click OK to save the modification.
   Parent topic: Managing a Security Group
