Restrictions and Limitations
This section describes the restrictions on using OBS features.
Item |
Description |
Bandwidth |
By default, the maximum bandwidth for read/write (GET/PUT) requests of a single account is 16 Gbit/s. If the actual bandwidth reaches the threshold, flow control will be triggered. |
Queries per second (QPS) |
Default maximum QPS allowed by a single account:
If you use sequential prefixes (such as timestamps or alphabetical order) for object naming, object access requests may be concentrated in a specific partition, resulting in access hotspots. This limits the request rate in a hotspot partition and increases access delay. Random prefixes are recommended for naming objects so that requests are evenly distributed across partitions, achieving horizontal expansion. |
Access rules |
In consideration of the DNS resolution performance and reliability, OBS requires that the bucket name must precede the domain when a request carrying a bucket name is constructed to form a three-level domain name, also mentioned as virtual-hosted-style access domain name. For example, you have a bucket named test-bucket in the eu-west-0 region, and you want to access the ACL of an object named test-object in the bucket. The correct URL is https://test-bucket.oss.eu-west-0.prod-cloud-ocb.orange-business.com/test-object?acl. |
Buckets |
Uploading objects |
Deleting objects |
If versioning is not enabled for a bucket, deleted objects cannot be recovered. |
Restoring Cold objects |
Lifecycle management |
There is no limit on the number of lifecycle rules in a bucket, but the total size of XML descriptions about all lifecycle rules in a bucket cannot exceed 20 KB. |
Cross-region replication |
User-defined domain name binding |
ACLs |
Bucket policies |
There is no limit on the number of bucket policies (statements) for a bucket, but the JSON descriptions of all bucket policies in a bucket cannot exceed 20 KB in total. |
Parallel file systems |
See the Object Storage Service Parallel File System Feature Guide. |
