Error Code List
If a request fails to be processed due to errors, an error response is returned. An error response contains an error code and error details. Table 1 lists some common error codes in OBS error responses.
       Error Code  |
       Description  |
       Obs.0000  |
       Invalid parameter.  |
       Obs.0001  |
       All access requests to this object are invalid.  |
       Obs.0002  |
       The absolute path of a file cannot exceed 1023 characters. Please retry.  |
       Obs.0003  |
       The connection timed out.  |
       Obs.0004  |
       Time difference is longer than 15 minutes between the client and server. Correctly set the local time. For security purposes, OBS verifies the time offset between the client and server. If the offset is longer than 15 minutes, the OBS server will reject your requests and this error message is reported. To resolve this problem, adjust your local time (UTC) and try again.  |
       Obs.0005  |
       The server load is too heavy. Try again later.  |
       Obs.0006  |
       The number of buckets has reached the upper limit. An account (including all IAM users under this account) can create a maximum of 100 buckets and parallel file systems. You can use the fine-grained access control of OBS to properly plan and use buckets.  |
       Obs.0007  |
       The target bucket does not exist or is not in the same region with the current bucket.  |
       Obs.0008  |
       The account has not been registered with the system. Only a registered account can be used.  |
       Obs.0009  |
       A conflicting operation is being performed on this resource. Please retry. This is because that there is a bucket with the same name as the bucket you are creating in OBS and the existing bucket has been released in the recent period due to arrears. In such case, try another bucket name.  |
       Obs.0010  |
       Deletion failed. Check whether objects or objects of historical versions exist in the bucket.  |
       Obs.0011  |
       The bucket policy is invalid. Configure it again.  |
       Obs.0012  |
       The requested bucket name already exists. Bucket namespace is shared by all users in the system. Enter a different name and try again.  |
       Obs.0013  |
       The requested folder name already exists. Enter a different name and try again.  |
       Obs.0014  |
       The file size has exceeded 50 MB. Use OBS Browser to upload it.  |
       Obs.0015  |
       The absolute path in the search criteria cannot exceed 1023 characters. Please retry.  |
       Obs.0016  |
       Upload failed. Possible causes:
       Obs.0017  |
       The end time of the new validity period must be later than that of the old validity period.  |
       Obs.0018  |
       The validity period cannot be shorter than the remaining period.  |
       Obs.0019  |
       Cannot determine whether the bucket has objects or fragments. Check whether you have the read permission for this bucket.  |
       Obs.0020  |
       TMS system error. Try again later.  |
       Obs.0021  |
       You do not have permissions to access TMS. Configure the required permissions in IAM.  |
       Obs.0022  |
       The TMS system is busy. Try again later.  |
