OBS Monitoring Metrics
Functions
This section defines the namespace, list, and dimensions of monitoring metrics reported by OBS to Cloud Eye. You can use the management console or APIs provided by Cloud Eye to search for monitoring metrics and alarms generated by OBS.
Namespace
SYS.OBS
Monitoring Metrics
Metric ID |
Metric |
Description |
Value Range |
Monitored Entity |
Monitoring Period (Original Metric) |
download_bytes |
Bytes Downloaded |
Specifies the response bytes of all download requests made to all buckets in a region, including bytes in HTTP entity bodies. Unit: byte |
≥ 0 bytes |
Bucket |
5 min |
upload_bytes |
Bytes Uploaded |
Specifies the bytes of all upload requests made to all buckets in a region, including bytes in HTTP entity bodies. Unit: byte |
≥ 0 bytes |
Bucket |
5 min |
get_request_count |
GET Requests |
Specifies the number of GET, HEAD, or OPTIONS requests made to all buckets and objects in the buckets of a region. Unit: count |
≥ 0 counts |
Bucket |
5 min |
put_request_count |
PUT Requests |
Specifies the number of PUT, POST, and DELETE requests made to all buckets and objects in the buckets of a region. Unit: count |
≥ 0 counts |
Bucket |
5 min |
first_byte_latency |
First Byte Download Delay |
Specifies the average time from receiving a GET, HEAD, or OPTIONS request to the time that the system starts to respond in a measurement period. Unit: ms |
≥ 0 ms |
Bucket |
5 min |
request_count_4xx |
4xx Errors |
Specifies the times that the server responds to requests whose error codes are 4xx. Unit: count |
≥ 0 counts |
Bucket |
5 min |
request_count_5xx |
5xx Errors |
Specifies the times that the server responds to requests whose error codes are 5xx. Unit: count |
≥ 0 counts |
Bucket |
5 min |
Dimensions
Key |
Value |
bucket_name |
Bucket dimension. The value is the bucket name. |
