Log Structuring Fields
Setting Log Structuring Fields
You can edit extracted fields after log structuring.
Structuring Method |
Field Name |
Field Type Can Be Changed |
Field Can Be Deleted |
Regular expressions (auto generate) |
User-defined. The name must start with a letter and contain only letters and digits. |
Yes |
Yes |
Regular expressions (manually enter) |
Yes |
Yes |
JSON |
Names are set automatically, but you can set aliases for fields. |
Yes |
Yes |
Delimiter |
Default names such as field1, field2, field3 are used. You can modify these names. |
Yes |
Yes |
Nginx |
Names are set based on Nginx configuration, but you can set aliases for fields. |
Yes |
Yes |
ELB structuring template |
Defined by ELB. |
No |
No |
VPC structuring template |
Defined by VPC. |
No |
No |
CTS structuring template |
Keys in JSON log events. |
No |
No |
APIG structuring template |
Defined by APIG. |
No |
No |
DCS audit logs |
Defined by DCS. |
No |
No |
Tomcat |
Defined by Tomcat. |
No |
No |
Nginx |
Defined by Nginx. |
No |
No |
GAUSSV5 audit logs |
Defined by GAUSSV5. |
No |
No |
DDS audit logs |
Defined by DDS. |
No |
No |
DDS error logs |
Defined by DDS. |
No |
No |
DDS slow query logs |
Defined by DDS. |
No |
No |
CFW access control logs |
Defined by CFW. |
No |
No |
CFW attack logs |
Defined by CFW. |
No |
No |
CFW traffic logs |
Defined by CFW. |
No |
No |
MySQL error logs |
Defined by MySQL. |
No |
No |
MySQL slow query logs |
Defined by MySQL. |
No |
No |
PostgreSQL error logs |
Defined by PostgreSQL. |
No |
No |
SQL Server error logs |
Defined by SQL Server. |
No |
No |
GaussDB(for Redis) slow query logs |
Defined by GaussDB(for Redis). |
No |
No |
CDN |
Defined by CDN. |
No |
No |
SMN |
Defined by SMN. |
No |
No |
GaussDB_MySQL error logs |
Defined by GaussDB_MySQL. |
No |
No |
GaussDB_MySQL slow query logs |
No |
No |
Enterprise Router |
Defined by ER. |
No |
No |
MySQL audit logs |
Defined by MySQL. |
No |
No |
GaussDB(for Cassandra) slow query logs |
Defined by GaussDB(for Cassandra). |
No |
No |
GaussDB(for Mongo) slow query logs |
Defined by GaussDB(for Mongo). |
No |
No |
GaussDB(for Mongo) error logs |
No |
No |
Custom templates |
User-defined. |
Yes |
Yes |
When you use regular expressions (manually entered), JSON, delimiters, Nginx, or custom templates to structure logs, field names:
- Can contain only letters, digits, hyphens (-), underscores (_), and periods (.).
- Cannot start with a period (.) or underscore (_) or end with a period (.).
- Can contain 1 to 64 characters.
Setting Tag Fields
When you structure logs, you can configure tag fields, so you can use these fields to run SQL queries on the Visualization page.
- During field extraction, click the Tag Fields tab.
- Click Add Field.
- In the Field column, enter the name of the tag field, for example, hostIP.
If you configure tag fields for a structuring rule that was created before the function of tag fields was brought online, no example values will be shown with the tag fields.
- To add more fields, click Add Field.
- Click Save to save the settings.
- Tag fields can be the following system fields: category, clusterId, clusterName, containerName, hostIP, hostId, hostName, nameSpace, pathFile, and podName.
- Tag fields cannot be the following system fields: groupName, logStream, lineNum, content, logContent, logContentSize, and collectTime.
- You can configure both field extraction and tag fields during log structuring.
