Updated on 2025-09-19 GMT+08:00
Structuring Templates
LTS supports two types of structuring templates: system templates and custom templates.
System Templates
You can choose from multiple system templates, but cannot modify the field types in them or delete the fields. For details, see Table 1.
  1. Click System template and select a template. A sample log event is displayed for each template.
  1. When you select a template, the log parsing result is displayed in the Template Details area. Click Save.
    • During log structuring, if a system template is used, the time in the system template is the customized log time.
    • Fields of the string type do not support range query using the >, =, or < operators or the "in" syntax. Use asterisks (*) or question marks (?) for fuzzy query. You need to reconfigure the structuring and change the value of this field to a number.
    Table 1 System template fields
    Structuring Method
    Field Name
    Field Type Can Be Changed
    Field Can Be Deleted
    ELB structuring template
    Defined by ELB.
    No
    No
    VPC structuring template
    Defined by VPC.
    No
    No
    CTS structuring template
    Keys in JSON log events.
    No
    No
    APIG structuring template
    Defined by APIG.
    No
    No
    DCS audit logs
    Defined by DCS.
    No
    No
    Tomcat
    Defined by Tomcat.
    No
    No
    Nginx
    Defined by Nginx.
    No
    No
    GAUSSV5
    Defined by GAUSSV5.
    No
    No
    DDS audit logs
    Defined by DDS.
    No
    No
    DDS error logs
    Defined by DDS.
    No
    No
    DDS slow query logs
    Defined by DDS.
    No
    No
    CFW access control logs
    Defined by CFW.
    No
    No
    CFW attack logs
    Defined by CFW.
    No
    No
    CFW traffic logs
    Defined by CFW.
    No
    No
    MySQL error logs
    Defined by MySQL.
    No
    No
    MySQL slow query logs
    Defined by MySQL.
    No
    No
    PostgreSQL slow query logs
    Defined by PostgreSQL.
    No
    No
    PostgreSQL error logs
    No
    No
    SQL Server error logs
    Defined by SQL Server.
    No
    No
    GaussDB(for Redis) slow query logs
    Defined by GeminiDB Redis.
    No
    No
    SMN
    Defined by SMN.
    No
    No
    GAUSSDB_MYSQL error logs
    Defined by GaussDB_MySQL.
    No
    No
    GaussDB_MySQL slow query logs
    No
    No
    ER Enterprise Router
    Defined by ER.
    No
    No
    MySQL audit logs
    Defined by MySQL.
    No
    No
    GaussDB(for Cassandra) slow query logs
    Defined by GeminiDB Cassandra.
    No
    No
    GaussDB(for Mongo) slow query logs
    Defined by GeminiDB Mongo.
    No
    No
    GaussDB(for Mongo) error logs
    No
    No
    WAF access logs
    Defined by WAF.
    No
    No
    WAF attack logs
    Defined by WAF.
    No
    No
    DMS rebalancing logs
    Defined by DMS.
    No
    No
    CCE audit logs
    Defined by CCE.
    No
    No
    CCE event logs
    Defined by CCE.
    No
    No
    GaussDB(for Redis) audit logs
    No
    No
Custom Templates
Click Custom template and select a template. There are two ways to obtain a custom template:
  • When you extract fields using methods of regular expression, JSON, delimiter, or Nginx, click Save as Template in the lower left corner. In the displayed dialog box, enter the template name and click OK. The template will be displayed in the custom template list.
  • Create a custom template under the Structuring Template option.
    Select Custom template and click Create Template. Enter a template name, select Regular Expressions, JSON, Delimiter, or Nginx, configure the template, and click Save. The template will be displayed in the custom template list.
