Updated on 2025-09-19 GMT+08:00
Log Collection
To reduce the memory, database, and disk space usage, you can set log collection as required. The log collection switch is used to determine whether to collect log data.
  1. Log in to the LTS console, choose Configuration Center in the navigation pane on the left, and click the ICAgent Collection tab.
  2. Enable or disable ICAgent Collection.
    Figure 1 Enabling or disabling log collection
    This function is enabled by default. If you do not need to collect logs, disable this function to reduce resource usage.
    After the log collection function is disabled, ICAgent will stop collecting logs, and this function on the AOM console will also be disabled.
