- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Granting LTS Permissions to IAM Users
- Purchasing LTS Resource Packages
- Log Management
Log Ingestion
- Overview
Using ICAgent to Collect Logs
- Overview
- Installing ICAgent (Intra-Region Hosts)
- Installing ICAgent (Extra-Region Hosts)
- Managing ICAgent
- Managing Host Groups
- Ingesting BMS Text Logs to LTS
- Ingesting CCE Application Logs to LTS
- Ingesting ECS Text Logs to LTS
- Ingesting ServiceStage Containerized Application Logs to LTS
- Ingesting ServiceStage Cloud Host Logs to LTS
- Ingesting Self-Built Kubernetes Application Logs to LTS
- Setting ICAgent Structuring Parsing Rules
Ingesting Cloud Service Logs to LTS
- Overview
- Ingesting AOM Logs to LTS
- Ingesting APIG Logs to LTS
- Ingesting CBH Logs to LTS
- Ingesting CFW Logs to LTS
- Ingesting CTS Logs to LTS
- Ingesting DDS Logs to LTS
- Ingesting DMS for Kafka Logs to LTS
- Ingesting DRS Logs to LTS
- Ingesting GaussDB(DWS) Logs to LTS
- Ingesting ELB Logs to LTS
- Ingesting Enterprise Router Logs to LTS
- Ingesting FunctionGraph Logs to LTS
- Ingesting GaussDB Logs to LTS
- Ingesting GES Logs to LTS
- Ingesting TaurusDB Logs to LTS
- Ingesting GeminiDB Logs to LTS
- Ingesting GeminiDB Mongo Logs to LTS
- Ingesting GeminiDB Cassandra Logs to LTS
- Ingesting IoTDA Logs to LTS
- Ingesting ModelArts Logs to LTS
- Ingesting MRS Logs to LTS
- Ingesting RDS for MySQL Logs to LTS
- Ingesting RDS for PostgreSQL Logs to LTS
- Ingesting RDS for SQL Server Logs to LTS
- Ingesting ROMA Connect Logs to LTS
- Ingesting SMN Logs to LTS
- Ingesting SecMaster Logs to LTS
- Ingesting OBS Files to LTS (Beta)
- Ingesting VPC Logs to LTS
- Ingesting WAF Logs to LTS
- Using APIs to Ingest Logs to LTS
- Ingesting Logs to LTS Across IAM Accounts
- Using Kafka to Report Logs to LTS
- Using Flume to Report Logs to LTS
- Log Search and Analysis
Log Visualization
- Overview
- Visualizing Logs in Statistical Charts
Visualizing Logs in Dashboards
- Creating a Dashboard
- Adding a Dashboard Filter
Dashboard Templates
- APIG Dashboard Templates
- CCE Dashboard Templates
- CDN Dashboard Templates
- CFW Dashboard Templates
- CSE Dashboard Templates
- DCS Dashboard Template
- DDS Dashboard Template
- DMS Dashboard Template
- DSL Dashboard Template
- ER Dashboard Template
- METRIC Dashboard Template
- Nginx Dashboard Templates
- VPC Dashboard Template
- WAF Dashboard Templates
- Log Alarms
- Log Transfer
- Log Processing
- Configuration Center
- Querying Real-Time LTS Traces
Best Practices
- Overview
Log Ingestion
- Collecting Logs from Third-Party Cloud Vendors, Internet Data Centers, and Other Huawei Cloud Regions to LTS
- Collecting Kubernetes Logs from Third-Party Clouds, IDCs, and Other Huawei Cloud Regions to LTS
- Collecting Syslog Aggregation Server Logs to LTS
- Importing Logs of Self-built ELK to LTS
- Collecting Zabbix Data Through ECS Log Ingestion
- Collecting Logs from Multiple Channels to LTS
- Log Transfer
- Billing
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- API Calling Examples
- Examples
APIs
- Host Group Management
- Log Group Management
- Log Stream Management
- Log Management
- Log Ingestion
- Log Transfer
- Log Collection Beyond Free Quota
- Cloud Log Structuring
- Container Log Ingestion from AOM to LTS
- Alarm Topics
- Message Template Management
- SQL Alarm Rules
- Keyword Alarm Rules
- Alarm List
- Tag Management
- Dashboard Management
- Log Charts
- Quick Search
- Multi-Account Log Aggregation
- Appendix
- SDK Reference
- Overview
- Consultation
- Log Management
Host Management
- What Do I Do If ICAgent Installation Fails in Windows and the Message "SERVICE STOP" Is Displayed?
- What Do I Do If ICAgent Upgrade Fails on the LTS Console?
- What Do I Do If I Could Not Query New Logs on LTS?
- What Do I Do If ICAgent Restarts Repeatedly After Being Installed?
- What Do I Do If ICAgent Is Displayed as Offline on the LTS Console After Installation?
- What Do I Do If I Do Not See a Host with ICAgent Installed on the LTS Console?
- How Do I Create a VPC Endpoint on the VPCEP Console?
- How Do I Obtain an AK/SK Pair?
- How Do I Install ICAgent by Creating an Agency?
Log Ingestion
- What Do I Do If LTS Cannot Collect Logs After I Configure Host Log Ingestion?
- Will LTS Stop Collecting Logs After the Free Quota Is Used Up If I Disable "Continue to Collect Logs When the Free Quota Is Exceeded" in AOM?
- What Do I Do If the CPU Usage Is High When ICAgent Is Collecting Logs?
- What Kinds of Logs and Files Does LTS Collect?
- How Do I Disable the Function of Collecting CCE Standard Output Logs to AOM on the LTS Console?
- What Log Rotation Scheme Should I Use for ICAgent to Collect Logs?
- Does LTS Use the Log4j Plug-in to Report Logs?
- How Long Does It Take to Generate Logs After Configuring Log Ingestion?
- What Do I Do If LTS Cannot Collect Logs After I Configure Log Ingestion with ICAgent?
Log Transfer
- Does LTS Delete Logs That Have Been Transferred to OBS Buckets?
- What Are the Common Causes of LTS Log Transfer Abnormalities?
- How Do I Transfer CTS Logs to an OBS Bucket?
- What Do I Do If I Cannot View Historical Data in an OBS Bucket After Transferring Data from LTS to OBS?
- What Do I Do If I Cannot Find a New Partition in a DLI Table After Logs Are Transferred to DLI?
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
- User Guide(Paris Regions)
- API Reference(Paris Regions)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- Calling APIs
- APIs
- Appendix
- Change History
- Videos
Configuring Keyword Alarms
LTS allows you to collect statistics on log keywords and set alarm rules to monitor them. By checking the number of keyword occurrences in a specified period, you can have a real-time view of the service running. Currently, up to 200 keyword alarms can be created for each account.
You have created log groups and log streams.
Creating an Alarm Rule
- Log in to the LTS console, and choose Alarms in the navigation pane on the left.
- Click the Alarm Rules tab.
- Click Create. The Create Alarm Rule right panel is displayed.
- Configure an alarm rule.
Table 1 Alarm rule parameters Parameter
Verification Rule
Example Value
Rule Name
Name of the alarm rule.
The name can contain 1 to 64 characters including only letters, digits, hyphens (-), underscores (_), and periods (.). It cannot start with a period or underscore or end with a period.
LTS-Alarm
Rule description.
Enter up to 64 characters.
Statistics
Select By keyword.
By keyword
Log Group Name
Select a log group.
Log Stream Name
Select a log stream.
Keywords
Enter keywords that you want LTS to monitor in logs.
Exact and fuzzy matches are supported. A keyword is case-sensitive and contains up to 1024 characters.
hostIP:192
Query Time Range
Time range for the keyword query, which is one period earlier than the current time. For example, if the Query Time Range is set to one hour and the current time is 9:00, the period of the keyword query is 8:00–9:00.
- The value ranges from 1 to 60 in the unit of minutes.
- The value ranges from 1 to 24 in the unit of hours.
1 h
Query Frequency
The options for this parameter are:
- Hourly: The query is performed at the top of each hour.
- Daily: The query is run at a specific time every day.
- Weekly: The query is run at a specific time on a specific day every week.
- Custom interval: You can specify the interval from 1 minute to 60 minutes or from 1 hour to 24 hours. For example, if the current time is 9:00 and the Custom interval is set to 5 minutes, the first query is at 9:00, the second query is at 9:05, the third query is at 9:10, and so on.
When the query time range is set to a value larger than 1 hour, the query frequency must be set to every 5 minutes or a lower frequency.
- CRON: CRON expressions support schedules down to the minute and use 24-hour format. Examples:
- 0/10 * * * *: The query starts from 00:00 and is performed every 10 minutes. That is, queries start at 00:00, 00:10, 00:20, 00:30, 00:40, 00:50, 01:00, and so on. For example, if the current time is 16:37, the next query is at 16:50.
- 0 0/5 * * *: The query starts from 00:00 and is performed every 5 hours at 00:00, 05:00, 10:00, 15:00, 20:00, and so on. For example, if the current time is 16:37, the next query is at 20:00.
- 0 14 * * *: The query is run at 14:00 every day.
- 0 0 10 * *: The query is run at 00:00 on the 10th day of every month.
Daily 01:00
Matching Log Events
When the number of log events that contain the configured keywords reaches the specified value, an alarm is triggered.
Four comparison operators are supported: greater than (>), greater than or equal to (>=), less than (<), and less than or equal to (<=).
The minimum value is 1 and the maximum value is 2147483647.
>10
Triggers
Configure a condition that will trigger the alarm.
Specify the number of statistical periods and the number of times the condition must be met to trigger the alarm. The number of statistical periods must be greater than or equal to the number of times the condition must be met.
Statistical periods: 1–10
4, 2
Alarm Severity
Possible values are critical (default), major, minor, and info.
critical
Send Notifications
Possible values are No (default) and Yes.
No
SMN Topic
If you select Yes for Send Notifications, select a Simple Message Notification (SMN) topic. You can select multiple topics.
If there are no topics that you desire, click Create Topic.
If you want to change the time zone or language, click Modify and set the preferences in the account center.
This parameter is required when Send Notifications is set to Yes.
- Click OK. The keyword alarm rule is created.
You can also choose Log Management in the navigation pane, and select a log stream. On the page displayed, click the Raw Logs tab and click
in the upper right corner. On the Settings page displayed, click the Alarms Rules tab and Create to create an alarm rule.
After an alarm rule is created, Status is enabled by default. When Status is enabled, an alarm will be triggered if the alarm rule is met. When Status is disabled, an alarm will not be triggered even if the alarm rule is met.
Modifying an Alarm Rule
- Click Modify in the Operation column of the row that contains the target alarm rule, and modify the parameters by referring to Table 1. Rule Name and Statistics cannot be modified.
- Click OK.
Deleting an Alarm Rule
- Click Delete in the Operation column of the row that contains the target alarm rule, and click OK.
