Billing (Dedicated Load Balancers)
This section describes how dedicated load balancers will be billed.
Billing Items
The following table describes the billing items of dedicated load balancers.
Billing Mode |
Load Balancer |
LCU |
Billing Formula |
Pay-per-use |
Load balancer price + LCU price
The load balancers are free of charge. You only need to pay for the LCUs. |
Table 2 describes the billing items.
Billing Item |
Description |
Load balancer |
You will be charged for the duration that you use the dedicated load balancer. If the load balancer is used for less than 1 hour, you will be charged for the actual duration, accurate to seconds. |
LCU |
You will be charged for the number of LCUs used by a dedicated load balancer. |
- √ indicates that the billing item is involved. × indicates that the billing item is not involved.
- An LCU measures the dimensions on which a dedicated load balancer routes the traffic. The four dimensions measured are as follows:
- New connections: the number of new connections that a dedicated load balancer establishes per second
- Maximum concurrent connections: the maximum number of concurrent connections that a dedicated load balancer can handle
- Queries per second: the number of Layer-7 HTTP or HTTPS requests that a dedicated load balancer routes to a backend server per second
- Processed traffic: each GB of data transferred through a dedicated load balancer
- If you bind an EIP to a dedicated load balancer, you will also be charged for the EIP and the bandwidth used by the EIP.
Billing Mode
Dedicated load balancers can be billed on a pay-per-use basis.
Dedicated load balancers provide Layer-4 packages and Layer-7 packages. You can select a Layer-4 package, a Layer-7 package, or both based on your requirements.
- Pay-per-use
Formula: Total price = Load balancer price + LCU price
- Load balancer price = Unit price (EUR/hour) x Usage duration
- LCU price = Unit price (EUR/hour) x LCU quantity in a single AZ x Number of AZs x Usage duration
