- What's New
- Function Overview
- Getting Started
User Guide
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Intelligent Resolution
- Resolver
- Permissions Management
- Using CTS to Collect DNS Key Operations
- Access Logging
- Quota Adjustment
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs
- Examples
- Appendix
- SDK Reference
DNS Overview
- Will I Be Billed for the DNS Service?
- How Many Zones, PTR Records, and Record Sets Can I Create?
- What Are Huawei Cloud DNS Servers?
- What Are Huawei Cloud Private DNS Server Addresses?
- What Are the Differences Between Public and Private Domain Names?
- Does DNS Support IPv6?
- Does DNS Support Explicit Forwarding and Implicit Forwarding?
- Does DNS Support Dynamic Domain Name Resolution?
- Does DNS Support Wildcard Entries?
- What Is TTL?
- How Many Domain Name Levels Does DNS Support?
- How Are Zones Queried to Resolve a Domain Name?
- What Are the Priorities of Resolution Lines?
- Why Was the Email Address Format Changed in the SOA Record?
- What Is CAA?
- Why Should I Set Priority For an MX Record Set?
- Can DNS Point a Domain Name to a Specific Port?
- Invalid Domain Resolution
- Website Access Failures
Public Zones
- Why Is a Message Indicating Conflict with an Existing Record Set Displayed When I Add a Record Set?
- How Do I Handle the Conflict Between CNAME and MX Record Sets?
- How Do I Add Record Sets to Subdomains?
- Which IP Address Is Returned for the Domain Name If There Are Multiple IP Addresses in a Record Set?
- Can I Modify a Zone?
- Can DNS Translate a Domain Name to IP Addresses of On-premises Servers or Third-Party Servers?
- How Can Multiple Domain Names Be Linked to the Same Website?
- Configuring Weighted Routing
- Can DNS Resolve a Domain Name that Has Not Been Licensed?
- How Do I Change the DNS Servers of a Domain Name?
- How Do I Handle Inaccurate Scheduling Caused by the CNAME Record Set Cache in the Default Lines?
Private Zones
- How Do I Change Default DNS Servers of an ECS to Huawei Cloud Private DNS Servers?
- How Can I Access an ECS Using Its Host Name?
- How Can I Map the Private IP Address of an ECS to a Domain Name?
- How Can I Use a Private Domain Name to Route Internet Traffic?
- Can I Use Private Domain Names Across Regions?
- Do I Need to Register Private Domain Names?
- Will a Deleted VPC Be Automatically Disassociated from the Private Zone?
- Are Private DNS Server Addresses the Same for All Users?
- What Are the Restrictions on Concurrent Private DNS Queries?
- Reverse Resolution
- Domain Transfer
DNS Overview
- Videos
More Documents
- Overview
- Getting Started
- Private Zone
- Record Set
- PTR Record
- Key Operations Recorded by CTS
- Quota Adjustment
- FAQs
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Overview
- Getting Started
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Quota Adjustment
FAQ
DNS Overview
- What Are DNS Servers?
- Does DNS Support Explicit and Implicit URLs?
- What Is TTL?
- What Is CAA?
Public Zones
- What Can I Do If There Is Message Indicating that the Public Zone Already Exists?
Private Zones
- What Are the Restrictions on Concurrent Private DNS Requests?
DNS Overview
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Private Zone
- Record Set
- Quota Adjustment
DNS Overview
- How Many Zones and Record Sets Can I Create?
- What Are the Private DNS Servers Provided by the DNS Service?
- Private Zones
DNS Overview
- Change History
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
- API Reference (Ankara Region)
- Glossary
A large website is generally deployed on multiple servers. To balance the load of each server, you can use weights to control the proportion of requests to each server.
The DNS service allows you to set weights to record sets to route the requests to different servers based on the specified weights.
When your website has multiple servers and each server has an independent IP address, consider weighted routing to distribute requests to different servers proportionally.
For example, you have a website deployed on three servers. The domain name of your website is example.com, and the IP addresses of the three servers are 192.168.1.1, 192.168.1.2, and 192.168.1.3.
- If you add an A record set and set its value to the three IP addresses, with no weights set to the IP addresses, requests are randomly routed to an IP address.
- You add three A record sets, with each having an IP address as its value.
In this case, you can set different weights for the three record sets. In this way, requests are routed to each server based on the specified weight.
Weighted routing can better distribute requests and balance server load. You can perform the operations provided in this section to set the weights.
You can configure weights for up to 20 record sets of the same domain name and line.
Preparations
There are three web servers. Three A record sets are required, with the value of each set to the IP address of a web server. You can set different weights to control the proportion of requests to each server.
Plan |
Domain Name |
Record Set Type |
Line Type |
Value |
Weight |
Description |
1 |
example.com |
A |
Default |
192.168.1.1 |
1 |
Requests are evenly distributed to three servers (the proportion of requests is 1:1:1). |
192.168.1.2 |
1 |
192.168.1.3 |
1 |
2 |
example.com |
A |
Default |
192.168.1.1 |
2 |
Requests are distributed to three servers in a proportion of 2:3:1. For example, if there are six requests, two are routed to the server whose IP address is 192.168.1.1, three are routed to the server whose IP address is 192.168.1.2, and one is routed to the server whose IP address is 192.168.1.3. |
192.168.1.2 |
3 |
192.168.1.3 |
1 |
The domain name of the website has been hosted on the DNS service.
The following describes how to add three A record sets to domain name example.com, and the weight ratio of the three record sets is 1:1:1.
- In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
- In the navigation pane on the left, choose Public Zones.
The Public Zones page is displayed.
- On the Public Zones page, click the domain name (example.com) of the public zone.
The Record Sets page is displayed.
- Click Add Record Set.
Figure 1 Setting weights
- Configure the parameters as follows:
- Name: Leave this parameter blank. The DNS service automatically considers example.com as the name, and requests are routed to example.com.
- Type: Set it to A – Map domains to IPv4 addresses.
- Line Type: Select Default.
- Value: Set it to 192.168.1.1, the IP address of a web server.
- Weight: Set it to 1.
- Click OK.
- Repeat 5 to 7 to add the second and third record sets.
Set the record set value to 192.168.1.2 and 192.168.1.3, respectively.
Requests will be evenly distributed to the three servers.
