A |
Maps domains to IPv4 addresses. |
IPv4 addresses mapped to the domain name
You can enter a maximum of 50 record values, each on a separate line. |
192.168.12.2
192.168.12.3 |
CNAME |
Maps one domain name to another domain name or multiple domain names to one domain name. |
Domain name alias. You can enter only one domain name. |
www.example.com |
MX |
Maps domain names to email servers. |
Email server address
The format is [priority][mail server host name].
Configuration rules:
- priority: priority for an email server to receive emails. A smaller value indicates a higher priority.
- mail server host name: domain name provided by the email service provider
10 mailserver.example.com.
20 mailserver2.example.com. |
AAAA |
Maps domain names to IPv6 addresses. |
IPv6 addresses mapped to the domain name
ff03:0db8:85a3:0:0:8a2e:0370:7334 |
TXT |
Creates text records for domain names. It is usually used in the following scenarios:
- To record DKIM public keys to prevent email fraud.
- To record the identity of domain name owners to facilitate domain name retrieval.
Text content
- Text record values must be enclosed in double quotation marks.
- One or more text record values are supported, each on a separate line.
A maximum of 50 text record values can be entered.
- A single text record value can contain multiple character strings, each of which is double quoted and separated from others using a space.
One character string cannot exceed 255 characters.
A value must not exceed 4096 characters.
- The value cannot be left blank.
- The text cannot contain a backslash (\).
- Single text record:
"aaa"
- Multiple text records:
"bbb"
"ccc"
- A text record that contains multiple strings:
"ddd" "eee" "fff"
SRV |
Records servers providing specific services. |
Server address
The value format is [priority] [weight] [port number] [server address].
If the record set values have the same priority, requests to the domain name will be routed based on weights.
2 1 2355 example_server.test.com |
NS |
Delegates subdomains to other name servers.
- For public zones, an NS record set is automatically created, and you can add NS record sets for subdomains.
- For private zones, an NS record set is automatically created, and you cannot add other NS record sets.
DNS server address
ns1.example.net
ns2.example.net |
SOA |
Identifies the base information about a domain name. The SOA record set is automatically generated by the DNS service and cannot be added manually. |
This type of record set is created by default and cannot be added manually. |
CAA |
Grants certificate issuing permissions to certificate authorities (CAs). CAA record sets can prevent the issuance of unauthorized HTTPS certificates. |
CA to be authorized to issue certificates for a domain name or its subdomains
The format is [flag] [tag] [value].
- flag: CA identifier, an unsigned character ranging from 0 to 255. Usually, the value is set to 0.
- tag: You can enter 1 to 15 characters, consisting of letters and digits from 0 to 9. The tag can be one of the following:
- issue: authorizes a CA to issue all types of certificates.
- issuewild: authorizes a CA to issue wildcard certificates.
- iodef: requests notifications once a CA receives invalid certificate requests.
- value: authorized CA or email address/URL required for notification once the CA receives invalid certificate requests. The value depends on the value of tag and must be enclosed in quotation marks (""). The value can contain a maximum of 255 characters, consisting of letters, digits, spaces, and special characters -#*?&_~=:;.@+^/!%
0 issue "ca.abc.com"
0 issuewild "ca.def.com"
0 iodef "mailto:admin@domain.com"
0 iodef "http:// domain.com/log/" |
PTR |
Maps IP addresses to domain names. |
Private domain name mapped to the private IP address. You can enter only one domain name. |
www.example.com |
