Viewing Traces
After CTS is enabled, the tracker starts recording operations on cloud resources. You can view operation records of the last 7 days on the CTS console.
This section describes how to query these records.
- Click
in the upper left corner and select the desired region and project. - In the service list, choose Management & Deployment > Domain Name Service.
- In the navigation pane, choose Trace List.
- Specify the filters used for querying traces. The following filters are available:
- Trace Type, Trace Source, Resource Type, and Search By
Select a filter from the drop-down list.
If you select Trace name for Search By, specify a trace name.
If you select Resource ID for Search By, specify a resource ID.
If you select Resource name for Search By, specify a resource name.
- Operator: Select a user who performs operations.
- Trace Status: Select All trace statuses, Normal, Warning, or Incident.
- Time range: Specify the start and end time to view traces generated during a time range of the last seven days.
- Click
on the left of the required trace to expand its details. - Click View Trace.
A dialog box is displayed, in which the trace structure details are displayed.
