Adding a TXT Record Set
A TXT record set provides description for a domain name.
For details about other record set types, see Record Set Types and Configuration Rules.
- In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
- In the navigation pane, choose Public Zones or Private Zones.
The zone list is displayed.
- (Optional) If you have selected Private Zones, click
on the upper left corner to select the region and project. - Click the domain name.
- Click Add Record Set.
The Add Record Set dialog box is displayed.
- Configure the parameters based on Table 1.
- Click OK.
- Switch back to the Record Sets tab.
You can view the added record set in the Normal state.
