On this page
Adding an NS Record Set
Updated on 2024-03-14 GMT+08:00
If you want to specify authoritative DNS servers for a domain name, you can add NS record sets.
For more details, see Record Set Types and Configuration Rules.
  • You can create NS record sets only in public zones.
  • After a public zone is created, an NS record set is automatically created for this zone and cannot be deleted. You can add NS record sets only in the following scenarios:
    • The Name parameter is not left blank. This means that you can add NS record sets for subdomains of a domain name.
    • The value of the Line parameter is not set to Default. This means that you can add NS record sets for the domain name with other resolution lines.
  2. In the service list, choose Network > Domain Name Service.
    The DNS console is displayed.
  3. In the navigation pane on the left, choose Public Zones.
    The Public Zones page is displayed.
  4. Click the domain name.
  5. Click Add Record Set.
    The Add Record Set dialog box is displayed.
  1. Configure the parameters based on Table 1.
    Table 1 Parameters for adding an NS record set
    Example Value
    Name
    Prefix of the domain name to be resolved.
    For example, if the domain name is example.com, the prefix can be as follows:
    • www: The domain name is www.example.com, which is usually used for a website.
    • Left blank: The domain name is example.com.
      The Name field cannot be set to an at sign (@). Just leave it blank.
    • abc: The domain name is abc.example.com, a subdomain of example.com.
    • mail: The domain name is mail.example.com, which is typically used for email servers.
    • *: The domain name is *.example.com, which is a wildcard domain name, indicating all subdomains of example.com.
    abc
    Type
    Type of the record set
    A message may be displayed indicating that the record set you are trying to add conflicts with an existing record set.
    NS – Delegate subdomains to other name servers
    TTL (s)
    Cache duration of the record set on a local DNS server, in seconds.
    The value ranges from 1 to 2147483647, and the default is 300.
    If your service address changes frequently, set TTL to a smaller value.
    300
    Value
    DNS server address
    You can enter a maximum of 50 record values, each on a separate line.
    ns1.example.net
    ns2.example.net
    Weight
    (Optional) Weight of a record set. The value ranges from 0 to 1000, and the default value is 1.
    This parameter is only designated for public domain names.
    If a resolution line in a zone contains multiple record sets of the same type, you can set different weights to each record set. For details, see Configuring Weighted Routing.
    (Optional) Supplementary information about the record set.
    You can enter a maximum of 255 characters.
  2. Switch back to the Record Sets tab.
    You can view the added record set in the Normal state.
