- What's New
- Function Overview
- Getting Started
User Guide
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Intelligent Resolution
- Resolver
- Permissions Management
- Using CTS to Collect DNS Key Operations
- Access Logging
- Quota Adjustment
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs
- Examples
- Appendix
- SDK Reference
DNS Overview
- Will I Be Billed for the DNS Service?
- How Many Zones, PTR Records, and Record Sets Can I Create?
- What Are Huawei Cloud DNS Servers?
- What Are Huawei Cloud Private DNS Server Addresses?
- What Are the Differences Between Public and Private Domain Names?
- Does DNS Support IPv6?
- Does DNS Support Explicit Forwarding and Implicit Forwarding?
- Does DNS Support Dynamic Domain Name Resolution?
- Does DNS Support Wildcard Entries?
- What Is TTL?
- How Many Domain Name Levels Does DNS Support?
- How Are Zones Queried to Resolve a Domain Name?
- What Are the Priorities of Resolution Lines?
- Why Was the Email Address Format Changed in the SOA Record?
- What Is CAA?
- Why Should I Set Priority For an MX Record Set?
- Can DNS Point a Domain Name to a Specific Port?
- Invalid Domain Resolution
- Website Access Failures
Public Zones
- Why Is a Message Indicating Conflict with an Existing Record Set Displayed When I Add a Record Set?
- How Do I Handle the Conflict Between CNAME and MX Record Sets?
- How Do I Add Record Sets to Subdomains?
- Which IP Address Is Returned for the Domain Name If There Are Multiple IP Addresses in a Record Set?
- Can I Modify a Zone?
- Can DNS Translate a Domain Name to IP Addresses of On-premises Servers or Third-Party Servers?
- How Can Multiple Domain Names Be Linked to the Same Website?
- Configuring Weighted Routing
- Can DNS Resolve a Domain Name that Has Not Been Licensed?
- How Do I Change the DNS Servers of a Domain Name?
- How Do I Handle Inaccurate Scheduling Caused by the CNAME Record Set Cache in the Default Lines?
Private Zones
- How Do I Change Default DNS Servers of an ECS to Huawei Cloud Private DNS Servers?
- How Can I Access an ECS Using Its Host Name?
- How Can I Map the Private IP Address of an ECS to a Domain Name?
- How Can I Use a Private Domain Name to Route Internet Traffic?
- Can I Use Private Domain Names Across Regions?
- Do I Need to Register Private Domain Names?
- Will a Deleted VPC Be Automatically Disassociated from the Private Zone?
- Are Private DNS Server Addresses the Same for All Users?
- What Are the Restrictions on Concurrent Private DNS Queries?
- Reverse Resolution
- Domain Transfer
DNS Overview
- Videos
More Documents
- Overview
- Getting Started
- Private Zone
- Record Set
- PTR Record
- Key Operations Recorded by CTS
- Quota Adjustment
- FAQs
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Overview
- Getting Started
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Quota Adjustment
FAQ
DNS Overview
- What Are DNS Servers?
- Does DNS Support Explicit and Implicit URLs?
- What Is TTL?
- What Is CAA?
Public Zones
- What Can I Do If There Is Message Indicating that the Public Zone Already Exists?
Private Zones
- What Are the Restrictions on Concurrent Private DNS Requests?
DNS Overview
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Private Zone
- Record Set
- Quota Adjustment
DNS Overview
- How Many Zones and Record Sets Can I Create?
- What Are the Private DNS Servers Provided by the DNS Service?
- Private Zones
DNS Overview
- Change History
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
- API Reference (Ankara Region)
- Glossary
Show all
Adding an AAAA Record Set
If you want end users to access your website, web application, or cloud server configured with an IPv6 address via its domain name, add an AAAA record set for this domain name.
For more details, see Record Set Types and Configuration Rules.
You have a web server and obtained an IPv6 address.
- In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
- In the navigation pane, choose Public Zones or Private Zones.
The zone list is displayed.
- (Optional) If you have selected Private Zones, click
on the upper left corner to select the region and project.
- Click the domain name.
- Click Add Record Set.
The Add Record Set dialog box is displayed.
- Configure the parameters based on Table 1.
Table 1 Parameters for adding an AAAA record set Parameter
Example Value
Name
Prefix of the domain name to be resolved.
For example, if the domain name is example.com, the prefix can be as follows:
- www: The domain name is www.example.com, which is usually used for a website.
- Left blank: The domain name is example.com.
The Name field cannot be set to an at sign (@). Just leave it blank.
- abc: The domain name is abc.example.com, a subdomain of example.com.
- mail: The domain name is mail.example.com, which is typically used for email servers.
- *: The domain name is *.example.com, which is a wildcard domain name, indicating all subdomains of example.com.
www
Type
Type of the record set.
A message may be displayed indicating that the record set you are trying to add conflicts with an existing record set.
AAAA – Map domains to IPv6 addresses
TTL (s)
Cache duration of the record set on a local DNS server, in seconds.
The value ranges from 1 to 2147483647, and the default is 300.
If your service address changes frequently, set TTL to a smaller value.
300
Value
IPv6 addresses mapped to the domain name
You can enter a maximum of 50 record values, each on a separate line.
ff03:0db8:85a3:0:0:8a2e:0370:7334
Weight
(Optional) Weight of a record set. The value ranges from 0 to 1000, and the default value is 1.
This parameter is only designated for public domain names.
If a resolution line in a zone contains multiple record sets of the same type, you can set different weights to each record set. For details, see Configuring Weighted Routing.
(Optional) Supplementary information about the record set.
You can enter a maximum of 255 characters.
- Click OK.
- Switch back to the Record Sets tab.
You can view the added record set in the Normal state.
