Adding an A Record Set
If you want end users to access your website, web application, or cloud server configured with an IPv4 address via its domain name, add an A record set for this domain name.
For more information about the types of record sets, see Record Set Types and Configuration Rules.
You have a website, web application, or cloud server and obtained an IPv4 address.
 - In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
 - In the navigation pane, choose Public Zones or Private Zones.
The zone list is displayed.
 - (Optional) If you have selected Private Zones, click
 on the upper left corner to select the region and project. - Click the domain name.
 - Click Add Record Set.
The Add Record Set dialog box is displayed.
 - Configure the parameters based on Table 1.
Table 1 Parameters for adding an A record set Parameter
Example Value
Name
Prefix of the domain name to be resolved.
For example, if the domain name is example.com, the prefix can be as follows:
- www: The domain name is www.example.com, which is usually used for a website.
 - Left blank: The domain name is example.com.
The Name field cannot be set to an at sign (@). Just leave it blank.
 - abc: The domain name is abc.example.com, a subdomain of example.com.
 - mail: The domain name is mail.example.com, which is typically used for email servers.
 - *: The domain name is *.example.com, which is a wildcard domain name, indicating all subdomains of example.com.
www
Type
Type of the record set.
A message may be displayed indicating that the record set you are trying to add conflicts with an existing record set.
A – Map domains to IPv4 addresses
TTL (s)
Cache duration of the record set on a local DNS server, in seconds.
The value ranges from 1 to 2147483647, and the default is 300.
If your service address changes frequently, set TTL to a smaller value.
300
Value
IPv4 addresses mapped to the domain name.
You can enter a maximum of 50 record values, each on a separate line.
192.168.12.2
192.168.12.3
Weight
(Optional) Weight of a record set. The value ranges from 0 to 1000, and the default value is 1.
This parameter is only designated for public domain names.
If a resolution line in a zone contains multiple record sets of the same type, you can set different weights to each record set. For details, see Configuring Weighted Routing.
(Optional) Supplementary information about the record set.
You can enter a maximum of 255 characters.
N/A
Table 2 Tag key and value requirements Parameter
Requirements
Example Value
Key
- Cannot be left blank.
 - Must be unique for each resource.
 - Can contain a maximum of 36 characters.
 - Cannot start or end with a space nor contain special characters =*<>\,|/
example_key1
Value
 - Can contain a maximum of 43 characters.
example_value1
 - Click OK.
 - Switch back to the Record Sets tab.
You can view the added record set in the Normal state.
Related Operations
For details about how to configure A record sets, see Routing Internet Traffic to a Website.
