Disassociating a VPC from a Private Zone
Disassociate a VPC from a private zone if you do not want the private domain name to be resolved in this VPC. If a private zone has only one VPC associated, you cannot disassociate the VPC.
If you do not intend to use private domain names, delete the private zone configured for it.
- In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
- In the navigation pane on the left, choose Private Zones.
The Private Zones page is displayed.
- Click
in the upper left corner and select the desired region and project.
- Locate the private zone from which a VPC is to be disassociated, select the VPC to be disassociated under Associated VPC, and click
on the right of the VPC. - In the Disassociate VPC dialog box, click Yes.
