Using UDFs
DLI allows you to query data by using the user-defined functions (Hive UDF).
- Compile a UDF.
Create or modify the content of SumUdfDemo.java in the sample code based on service requirements.
- Generate a JAR package, set the output JAR package to TestUDF.jar, and run the Build Artifacts command.
A file named TestUDF.jar is generated in the corresponding path, for example, udfDemo\target\artifacts\TestUDF.
- Upload TestUDF.jar to OBS. For details about how to upload data to OBS, see Step 2: Upload Data to OBS in Submitting a SQL Job.
- Create a function.
Run the following command on the management console to create a function:
CREATE FUNCTION fun1 AS 'com.demo.SumUdfDemo' using jar 'obs://udf/TestUDF.jar';
- Use the created function.
Run the following statement to query using the function created in 4.
select fun1(ip) from ip_tables;
- Delete the created function.
If this function is no longer used, run the following statement to delete the function:
Drop FUNCTION fun1;
Sample Code
The sample code in SumUdfDemo.java is as follows:
package com.demo;
import org.apache.hadoop.hive.ql.exec.UDF;
public class SumUdfDemo extends UDF {
public Int evaluate(Int a, Int b) {
return a + b;
