Readiness Probe
After a pod is created, the Service can immediately select it and forward requests to it. However, it takes time to start a pod. If the pod is not ready (it takes time to load the configuration or data, or a preheating program may need to be executed), the pod cannot process requests, and the requests will fail.
Kubernetes solves this problem by adding a readiness probe to pods. A pod with containers reporting that they are not ready does not receive traffic through Kubernetes Services.
A readiness probe periodically detects a pod and determines whether the pod is ready based on its response. Similar to Liveness Probe, there are three types of readiness probes.
  • Exec: kubelet executes a command in the target container. If the command succeeds, it returns 0, and kubelet considers the container to be ready.
  • HTTP GET: The probe sends an HTTP GET request to IP:port of the container. If the probe receives a 2xx or 3xx status code, the container is considered to be ready.
  • TCP Socket: The kubelet attempts to establish a TCP connection with the container. If it succeeds, the container is considered ready.
How Readiness Probes Work
Endpoints can be used as a readiness probe. When a pod is not ready, the IP:port of the pod is deleted from the Endpoint and is added to the Endpoint after the pod is ready, as shown in the following figure.
Figure 1 How readiness probes work
Exec
The Exec mode is the same as the HTTP GET mode. As shown below, the probe runs the ls /ready command. If the file exists, 0 is returned, indicating that the pod is ready. Otherwise, a non-zero status code is returned.
apiVersion: apps/v1
kind: Deployment
  replicas: 3
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      containers:
      - image: nginx:alpine
        resources:
          limits:
            cpu: 100m
            memory: 200Mi
          requests:
            cpu: 100m
            memory: 200Mi
        readinessProbe:      # Readiness Probe
          exec:              # Define the ls /ready command.
            command:
            - ls
            - /ready
      imagePullSecrets:
      - name: default-secret
Save the definition of the Deployment to the deploy-read.yaml file, delete the previously created Deployment, and use the deploy-read.yaml file to recreate the Deployment.
# kubectl delete deploy nginx
deployment.apps "nginx" deleted
# kubectl create -f deploy-read.yaml
deployment.apps/nginx created
The nginx image does not contain the /ready file. Therefore, the container is not in the Ready status after the creation, as shown below. Note that the values in the READY column are 0/1, indicating that the containers are not ready.
# kubectl get po
NAME                     READY     STATUS    RESTARTS   AGE
nginx-7955fd7786-686hp   0/1       Running   0          7s
nginx-7955fd7786-9tgwq   0/1       Running   0          7s
nginx-7955fd7786-bqsbj   0/1       Running   0          7s
Create a Service.
apiVersion: v1
kind: Service
  selector:
    app: nginx
  ports:
  - name: service0
    targetPort: 80
    port: 8080
    protocol: TCP
  type: ClusterIP
Check the Service. If there are no values in the Endpoints line, no Endpoints are found.
$ kubectl describe svc nginx
Endpoints:
If a /ready file is created in the container to make the readiness probe succeed, the container is in the Ready status. Check the pod and endpoints. It is found that the container for which the /ready file is created is ready and an endpoint is added.
# kubectl exec nginx-7955fd7786-686hp -- touch /ready
# kubectl get po -o wide
NAME                     READY     STATUS    RESTARTS   AGE       IP
nginx-7955fd7786-686hp   1/1       Running   0          10m       192.168.93.169
nginx-7955fd7786-9tgwq   0/1       Running   0          10m       192.168.166.130
nginx-7955fd7786-bqsbj   0/1       Running   0          10m       192.168.252.160
# kubectl get endpoints
NAME       ENDPOINTS           AGE
nginx      192.168.93.169:80   14d
HTTP GET
The configuration of a readiness probe is the same as that of a liveness probe and is also in the containers field of the pod description template. As shown below, the readiness probe sends an HTTP request to the pod. If the probe receives 2xx or 3xx, the pod is ready.
apiVersion: apps/v1
kind: Deployment
  replicas: 3
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      containers:
        resources:
          limits:
            cpu: 100m
            memory: 200Mi
          requests:
            cpu: 100m
            memory: 200Mi
        readinessProbe:           # readinessProbe
          httpGet:                # HTTP GET definition
            path: /read
            port: 80
      imagePullSecrets:
TCP Socket
The following example shows how to define a TCP Socket-type probe.
apiVersion: apps/v1
kind: Deployment
  replicas: 3
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      containers:
        resources:
          limits:
            cpu: 100m
            memory: 200Mi
          requests:
            cpu: 100m
            memory: 200Mi
          tcpSocket:                # TCP Socket definition
            port: 80
      imagePullSecrets:
Advanced Settings of a Readiness Probe
Similar to a liveness probe, a readiness probe also has the same advanced configuration items. The output of the describe command of the nginx pod is as follows:
Readiness: exec [ls /var/ready] delay=0s timeout=1s period=10s #success=1 #failure=3
This is the detailed configuration information of the readiness probe.
  • delay=0s indicates that the probe starts immediately after the container is started.
  • timeout=1s indicates that the container must respond to the probe within 1s. Otherwise, it is considered as a failure.
  • period=10s indicates that the probe is performed every 10s.
  • #success=1 indicates that the probe is considered successful as long as the probe succeeds once.
  • #failure=3 indicates that the probe is considered failed if it fails for three consecutive times.
These are the default configurations when the probe is created. You can customize them as follows:
          exec:              # Define the ls /readiness/ready command
            command:
            - ls
            - /readiness/ready
          initialDelaySeconds: 10     # Readiness probes are initiated after the container has started for 10s.
          timeoutSeconds: 2           # The container must respond within 2s. Otherwise, it is considered as a failure.
          periodSeconds: 30           # The probe is performed every 30s.
          successThreshold: 1         # The container is considered ready as long as the probe succeeds once.
          failureThreshold: 3        # The probe is considered to be failed after three consecutive failures.
