ConfigMap
Updated on 2023-12-07 GMT+08:00
A ConfigMap is a type of resource used to store the configurations required by applications. It is used to store configuration data or configuration files in key-value pairs.
A ConfigMap allows you to decouple configurations from your environments, so that your environments can use different configurations.
Creating a ConfigMap
In the following example, a ConfigMap named configmap-test is created. The ConfigMap configuration data is defined in the data field.
apiVersion: v1
kind: ConfigMap
data:                     # Configuration data
  property_1: Hello
  property_2: World
Referencing a ConfigMap as an Environment Variable
ConfigMaps are usually referenced as environment variables and in volumes.
In the following example, property_1 of configmap-test is used as the value of the environment variable EXAMPLE_PROPERTY_1. After the container is started, it will reference the value of property_1 as the value of EXAMPLE_PROPERTY_1, that is, Hello.
apiVersion: v1
kind: Pod
  containers:
  - image: nginx:alpine
    resources:
      limits:
        cpu: 100m
        memory: 200Mi
      requests:
        cpu: 100m
        memory: 200Mi
    env:
    - name: EXAMPLE_PROPERTY_1
      valueFrom:
        configMapKeyRef:          # Reference the ConfigMap.
          key: property_1
  imagePullSecrets:
  - name: default-secret
Referencing a ConfigMap in a Volume
Referencing a ConfigMap in a volume is to fill its data in configuration files in the volume. Each piece of data is saved in a file. The key is the file name, and the key value is the file content.
In the following example, create a volume named vol-configmap, reference the ConfigMap named configmap-test in the volume, and mount the volume to the /tmp directory of the container. After the pod is created, the two files property_1 and property_2 are generated in the /tmp directory of the container, and the values are Hello and World.
apiVersion: v1
kind: Pod
  containers:
    resources:
      limits:
        cpu: 100m
        memory: 200Mi
      requests:
        cpu: 100m
        memory: 200Mi
    volumeMounts:
    - name: vol-configmap           # Mount the volume named vol-configmap.
      mountPath: "/tmp"
  imagePullSecrets:
  volumes:
    configMap:                      # Reference the ConfigMap.
