Affinity and Anti-Affinity Scheduling
Updated on 2024-01-26 GMT+08:00
A nodeSelector provides a very simple way to constrain pods to nodes with particular labels, as mentioned in DaemonSet. The affinity and anti-affinity feature greatly expands the types of constraints you can express.
You can define affinity and anti-affinity in node and pod levels. You can configure custom rules to achieve affinity and anti-affinity scheduling. For example, you can deploy frontend pods and backend pods together, deploy the same type of applications on a specific node, or deploy different applications on different nodes.
Node Affinity
Node affinity is conceptually similar to a nodeSelector as it allows you to constrain which nodes your pod is eligible to be scheduled on, based on labels on the node. The following output lists the labels of node 192.168.0.212.
$ kubectl describe node 192.168.0.212
Roles:              <none>
Labels:             beta.kubernetes.io/arch=amd64
                    beta.kubernetes.io/os=linux
                    failure-domain.beta.kubernetes.io/is-baremetal=false
                    failure-domain.beta.kubernetes.io/region=eu-west-0
                    failure-domain.beta.kubernetes.io/zone=eu-west-0a
                    kubernetes.io/availablezone=eu-west-0a
                    kubernetes.io/eniquota=12
                    kubernetes.io/hostname=192.168.0.212
                    node.kubernetes.io/subnetid=fd43acad-33e7-48b2-a85a-24833f362e0e
                    os.architecture=amd64
                    os.name=EulerOS_2.0_SP5
                    os.version=3.10.0-862.14.1.5.h328.eulerosv2r7.x86_64
These labels are automatically added by CCE during node creation. The following describes a few that are frequently used during scheduling.
  • failure-domain.beta.kubernetes.io/region: region where the node is located. In the preceding output, the label value is eu-west-0, which indicates that the node is located in the Paris (France) region.
  • failure-domain.beta.kubernetes.io/zone: availability zone to which the node belongs.
  • kubernetes.io/hostname: host name of the node.
In addition to these automatically added labels, you can tailor labels to your service requirements, as introduced in Label for Managing Pods. Generally, large Kubernetes clusters have various kinds of labels.
When you deploy pods, you can use a nodeSelector, as described in DaemonSet, to constrain pods to nodes with specific labels. The following example shows how to use a nodeSelector to deploy pods only on the nodes with the gpu=true label.
apiVersion: v1
kind: Pod
  nodeSelector:                 #Node selection. A pod is deployed on a node only when the node has the gpu=true label.
    gpu: true
Node affinity rules can achieve the same results, as shown in the following example.
apiVersion: apps/v1
kind: Deployment
  labels:
    app:  gpu
  selector:
    matchLabels:
      app: gpu
  replicas: 3
  template:
      labels:
        app:  gpu
      containers:
      - image:  nginx:alpine
        resources:
          requests:
            cpu: 100m
            memory: 200Mi
          limits:
            cpu: 100m
            memory: 200Mi
      imagePullSecrets:
      - name: default-secret
      affinity:
        nodeAffinity:
          requiredDuringSchedulingIgnoredDuringExecution:
            nodeSelectorTerms:
            - matchExpressions:
              - key: gpu
                operator: In
                values:
                - "true"
Even though the node affinity rule requires more lines, it is more expressive, which will be further described later.
requiredDuringSchedulingIgnoredDuringExecution seems to be complex, but it can be easily understood as a combination of two parts.
  • The requiredDuringScheduling part indicates that the rule is a hard requirement, which means that the rule must be met for a pod to be scheduled onto a node.
  • The IgnoredDuringExecution part indicates that the pods that have been running on the node are not affected. Currently, all node affinity rules provided by Kubernetes end with IgnoredDuringExecution as these rules affect only the pods that are being scheduled. In the future, affinity rules end with RequiredDuringExecution will be supported, which means that pods will be evicted from nodes that cease to satisfy the pods' label requirements.
In addition, the value of operator is In, indicating that the label value must be in the values list. Other available operator values are as follows:
  • NotIn: The label value is not in a list.
  • Exists: A specific label exists.
  • DoesNotExist: A specific label does not exist.
  • Gt: The label value is greater than a specified value (string comparison).
  • Lt: The label value is less than a specified value (string comparison).
Note that there is no such thing as nodeAntiAffinity because operators NotIn and DoesNotExist provide the same function.
Now, check whether the node affinity rule takes effect. Add the gpu=true tag to the 192.168.0.212 node.
$ kubectl label node 192.168.0.212 gpu=true
node/192.168.0.212 labeled
$ kubectl get node -L gpu
NAME            STATUS   ROLES    AGE   VERSION                            GPU
192.168.0.212   Ready    <none>   13m   v1.15.6-r1-20.3.0.2.B001-15.30.2   true
192.168.0.94    Ready    <none>   13m   v1.15.6-r1-20.3.0.2.B001-15.30.2
192.168.0.97    Ready    <none>   13m   v1.15.6-r1-20.3.0.2.B001-15.30.2
Create the Deployment. You can find that all pods are deployed on the 192.168.0.212 node.
$ kubectl create -f affinity.yaml
deployment.apps/gpu created
$ kubectl get pod -o wide
NAME                     READY   STATUS    RESTARTS   AGE   IP            NODE
gpu-6df65c44cf-42xw4     1/1     Running   0          15s   172.16.0.37   192.168.0.212
gpu-6df65c44cf-jzjvs     1/1     Running   0          15s   172.16.0.36   192.168.0.212
gpu-6df65c44cf-zv5cl     1/1     Running   0          15s   172.16.0.38   192.168.0.212
Node Preference Rule
The preceding requiredDuringSchedulingIgnoredDuringExecution rule is a hard selection rule. There is another type of selection rule, that is, preferredDuringSchedulingIgnoredDuringExecution. It is used to specify which nodes are preferred during scheduling.
To demonstrate its effect, add a node to the cluster and ensure that the node is not in the same AZ with other nodes. After the node is created, query the AZ of the node. As shown in the following output, the newly added node is in eu-west-0a.
$ kubectl get node -L failure-domain.beta.kubernetes.io/zone,gpu
NAME            STATUS   ROLES    AGE     VERSION                            ZONE         GPU
192.168.0.100   Ready    <none>   7h23m   v1.15.6-r1-20.3.0.2.B001-15.30.2   eu-west-0a
192.168.0.212   Ready    <none>   8h      v1.15.6-r1-20.3.0.2.B001-15.30.2   eu-west-0b   true
192.168.0.94    Ready    <none>   8h      v1.15.6-r1-20.3.0.2.B001-15.30.2   eu-west-0b
192.168.0.97    Ready    <none>   8h      v1.15.6-r1-20.3.0.2.B001-15.30.2   eu-west-0b
Define a Deployment. Use the preferredDuringSchedulingIgnoredDuringExecution rule to set the weight of nodes in eu-west-0a as 80 and nodes with the gpu=true label as 20. In this way, pods are preferentially deployed on the node in eu-west-0a.
apiVersion: apps/v1
kind: Deployment
  labels:
    app:  gpu
  selector:
    matchLabels:
      app: gpu
  replicas: 10
  template:
      labels:
        app:  gpu
      containers:
        resources:
          requests:
            cpu:  100m
            memory:  200Mi
          limits:
            cpu:  100m
            memory:  200Mi
      imagePullSecrets:
      affinity:
        nodeAffinity:
          preferredDuringSchedulingIgnoredDuringExecution:
          - weight: 80
            preference:
              matchExpressions:
              - key: failure-domain.beta.kubernetes.io/zone
                operator: In
                values:
                - eu-west-0a
          - weight: 20
            preference:
              matchExpressions:
              - key: gpu
                operator: In
                values:
                - "true"
After the deployment, you can find that five pods are deployed on the 192.168.0.212 node, and two pods are deployed on the 192.168.0.100 node.
$ kubectl create -f affinity2.yaml
$ kubectl get po -o wide
gpu-585455d466-5bmcz   1/1     Running   0          2m29s   172.16.0.44   192.168.0.212
gpu-585455d466-cg2l6   1/1     Running   0          2m29s   172.16.0.63   192.168.0.97
gpu-585455d466-f2bt2   1/1     Running   0          2m29s   172.16.0.79   192.168.0.100
gpu-585455d466-hdb5n   1/1     Running   0          2m29s   172.16.0.42   192.168.0.212
gpu-585455d466-hkgvz   1/1     Running   0          2m29s   172.16.0.43   192.168.0.212
gpu-585455d466-mngvn   1/1     Running   0          2m29s   172.16.0.48   192.168.0.97
gpu-585455d466-s26qs   1/1     Running   0          2m29s   172.16.0.62   192.168.0.97
gpu-585455d466-sxtzm   1/1     Running   0          2m29s   172.16.0.45   192.168.0.212
gpu-585455d466-t56cm   1/1     Running   0          2m29s   172.16.0.64   192.168.0.100
gpu-585455d466-t5w5x   1/1     Running   0          2m29s   172.16.0.41   192.168.0.212
In the preceding example, the node scheduling priority is as follows. Nodes with both eu-west-0a and gpu=true labels have the highest priority. Nodes with the eu-west-0a label but no gpu=true label have the second priority (weight: 80). Nodes with the gpu=true label but no eu-west-0a label have the third priority. Nodes without any of these two labels have the lowest priority.
Figure 1 Scheduling priority
From the preceding output, you can find that no pods of the Deployment are scheduled to node 192.168.0.94. This is because the node already has many pods on it and its resource usage is high. This also indicates that the preferredDuringSchedulingIgnoredDuringExecution rule defines a preference rather than a hard requirement.
Pod Affinity
Node affinity rules affect only the affinity between pods and nodes. Kubernetes also supports configuring inter-pod affinity rules. For example, the frontend and backend of an application can be deployed together on one node to reduce access latency. There are also two types of inter-pod affinity rules: requiredDuringSchedulingIgnoredDuringExecution and preferredDuringSchedulingIgnoredDuringExecution.
Assume that the backend of an application has been created and has the app=backend label.
backend-658f6cb858-dlrz8   1/1     Running   0          2m36s   172.16.0.67   192.168.0.100
You can configure the following pod affinity rule to deploy the frontend pods of the application to the same node as the backend pods.
apiVersion: apps/v1
kind: Deployment
  labels:
    app:  frontend
  selector:
    matchLabels:
      app: frontend
  replicas: 3
  template:
      labels:
        app:  frontend
      containers:
        resources:
          requests:
            cpu:  100m
            memory:  200Mi
          limits:
            cpu:  100m
            memory:  200Mi
      imagePullSecrets:
      affinity:
        podAffinity:
          - topologyKey: kubernetes.io/hostname
            labelSelector:
              matchLabels:
                app: backend
Deploy the frontend and you can find that the frontend is deployed on the same node as the backend.
$ kubectl create -f affinity3.yaml
deployment.apps/frontend created
backend-658f6cb858-dlrz8    1/1     Running   0          5m38s   172.16.0.67   192.168.0.100
frontend-67ff9b7b97-dsqzn   1/1     Running   0          6s      172.16.0.70   192.168.0.100
frontend-67ff9b7b97-hxm5t   1/1     Running   0          6s      172.16.0.71   192.168.0.100
frontend-67ff9b7b97-z8pdb   1/1     Running   0          6s      172.16.0.72   192.168.0.100
The topologyKey field specifies the selection range. The scheduler selects nodes within the range based on the affinity rule defined. The effect of topologyKey is not fully demonstrated in the preceding example because all the nodes have the kubernetes.io/hostname label, that is, all the nodes are within the range.
To see how topologyKey works, assume that the backend of the application has two pods, which are running on different nodes.
backend-658f6cb858-5bpd6   1/1     Running   0          23m     172.16.0.40   192.168.0.97
Add the perfer=true label to nodes 192.168.0.97 and 192.168.0.94.
$ kubectl label node 192.168.0.97 perfer=true
node/192.168.0.97 labeled
$ kubectl label node 192.168.0.94 perfer=true
node/192.168.0.94 labeled
$ kubectl get node -L perfer
NAME            STATUS   ROLES    AGE   VERSION                            PERFER
192.168.0.100   Ready    <none>   44m   v1.15.6-r1-20.3.0.2.B001-15.30.2
192.168.0.212   Ready    <none>   91m   v1.15.6-r1-20.3.0.2.B001-15.30.2
192.168.0.94    Ready    <none>   91m   v1.15.6-r1-20.3.0.2.B001-15.30.2   true
192.168.0.97    Ready    <none>   91m   v1.15.6-r1-20.3.0.2.B001-15.30.2   true
Define topologyKey in the podAffinity section as prefer.
      affinity:
        podAffinity:
          - topologyKey: perfer
            labelSelector:
              matchLabels:
                app: backend
The scheduler recognizes the nodes with the perfer label, that is, 192.168.0.97 and 192.168.0.94, and then find the pods with the app=backend label. In this way, all frontend pods are deployed onto 192.168.0.97.
backend-658f6cb858-5bpd6    1/1     Running   0          26m     172.16.0.40   192.168.0.97
frontend-67ff9b7b97-dsqzn   1/1     Running   0          6s      172.16.0.70   192.168.0.97
frontend-67ff9b7b97-hxm5t   1/1     Running   0          6s      172.16.0.71   192.168.0.97
frontend-67ff9b7b97-z8pdb   1/1     Running   0          6s      172.16.0.72   192.168.0.97
Pod Anti-affinity
Unlike the scenarios in which pods are preferred to be scheduled onto the same node, sometimes, it could be the exact opposite. For example, if certain pods are deployed together, they will affect the performance.
The following example defines an inter-pod anti-affinity rule, which specifies that pods must not be scheduled to nodes that already have pods with the app=frontend label, that is, to deploy the pods of the frontend to different nodes with each node has only one replica.
apiVersion: apps/v1
kind: Deployment
  labels:
    app:  frontend
  selector:
    matchLabels:
      app: frontend
  replicas: 5
  template:
      labels:
        app:  frontend
      containers:
        resources:
          requests:
            cpu:  100m
            memory:  200Mi
          limits:
            cpu:  100m
            memory:  200Mi
      imagePullSecrets:
      affinity:
        podAntiAffinity:
            labelSelector:
              matchLabels:
                app: frontend
Deploy the frontend and query the deployment results. You can find that each node has only one frontend pod and one pod of the Deployment is Pending. This is because when the scheduler is deploying the fifth pod, all nodes already have one pod with the app=frontend label on them. There is no available node. Therefore, the fifth pod will remain in the Pending status.
$ kubectl create -f affinity4.yaml
frontend-6f686d8d87-8dlsc   1/1     Running   0          18s   172.16.0.76   192.168.0.100
frontend-6f686d8d87-d6l8p   0/1     Pending   0          18s   <none>        <none>
frontend-6f686d8d87-hgcq2   1/1     Running   0          18s   172.16.0.54   192.168.0.97
frontend-6f686d8d87-q7cfq   1/1     Running   0          18s   172.16.0.47   192.168.0.212
frontend-6f686d8d87-xl8hx   1/1     Running   0          18s   172.16.0.23   192.168.0.94
