On this page
Show all
Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ FAQs/ Chart and Add-on/ Why TLS v1.0 and v1.1 Cannot Be Used After the NGINX Ingress Controller Add-on Is Upgraded?
Symptom
After the NGINX Ingress Controller add-on is upgraded to 2.3.3 or later, if the TLS version of the client is earlier than v1.2, an error is reported during the negotiation between the client and NGINX Ingress Controller.
Solution
NGINX Ingress Controller 2.3.3 and later versions support only TLS v1.2 and v1.3 by default. If additional TLS versions are needed, you can add the @SECLEVEL=0 field to the ssl-ciphers parameter configured for the NGINX Ingress Controller add-on. For details, see TLS/HTTPS.
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons. Choose Installed from the drop-down list, click Manage under NGINX Ingress Controller.
  2. Click Edit of the corresponding instance.
  3. Add the following configuration to the Nginx Parameters:
    	"ssl-ciphers": "@SECLEVEL=0 ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA",
    	"ssl-protocols": "TLSv1 TLSv1.1 TLSv1.2 TLSv1.3"
  4. Click OK.
  5. Use TLS v1.1 for access again. The response is normal.
