On this page
How Do I Evict All Pods on a Node?
You can run the kubectl drain command to safely evict all pods from a node.
By default, the kubectl drain command retains some system pods, for example, everest-csi-driver.
  1. Use kubectl to connect to the cluster.
  2. Check the nodes in the cluster.
    kubectl get node
  3. Select a node and view all pods on the node.
    kubectl get pod --all-namespaces -owide --field-selector spec.nodeName=192.168.0.160
    The pods on the node before eviction are as follows:
    NAMESPACE     NAME                                      READY   STATUS    RESTARTS   AGE     IP              NODE            NOMINATED NODE   READINESS GATES
    default       nginx-5bcc57c74b-lgcvh                    1/1     Running   0          7m25s   10.0.0.140      192.168.0.160   <none>           <none>
    kube-system   coredns-6fcd88c4c-97p6s                   1/1     Running   0          3h16m   10.0.0.138      192.168.0.160   <none>           <none>
    kube-system   everest-csi-controller-56796f47cc-99dtm   1/1     Running   0          3h16m   10.0.0.139      192.168.0.160   <none>           <none>
    kube-system   everest-csi-driver-dpfzl                  2/2     Running   2          12d     192.168.0.160   192.168.0.160   <none>           <none>
    kube-system   icagent-tpfpv                             1/1     Running   1          12d     192.168.0.160   192.168.0.160   <none>           <none>
  4. Evict all pods on the node.
    kubectl drain 192.168.0.160
    If a pod mounted with local storage or controlled by a DaemonSet exists on the node, the message "eerror: unable to drain node "192.168.0.160" due to error: cannot delete DaemonSet-managed Pods..." will be displayed. The eviction command does not take effect. You can add the following parameters to the end of the preceding command to forcibly evict the pod:
    • --delete-emptydir-data: forcibly evicts pods mounted with local storage, for example, coredns.
    • --ignore-daemonsets: forcibly evicts the DaemonSet pods, for example, everest-csi-driver.
    In the example, both types of pods exist on the node. Therefore, the eviction command is as follows:
    kubectl drain 192.168.0.160 --delete-emptydir-data --ignore-daemonsets
  5. After the eviction, the node is automatically marked as unschedulable. That is, the node is tainted node.kubernetes.io/unschedulable = : NoSchedule.
    After the eviction, only system pods are retained on the node.
Related Operations
Drain, cordon, and uncordon operations of kubectl:
  • drain: Safely evicts all pods from a node and marks the node as unschedulable.
  • cordon: Marks the node as unschedulable. That is, the node is tainted node.kubernetes.io/unschedulable = : NoSchedule.
  • uncordon: Marks the node as schedulable.
For more information, see the kubectl documentation.
