What Can I Do If a Layer Is Missing During Image Pull?
Symptom
When containerd is used as the container engine, there is a possibility that the image layer is missing when an image is pulled to a node. As a result, the workload container fails to be created.
Possible Causes
Docker earlier than v1.10 supports the layer whose mediaType is application/octet-stream. However, containerd does not support application/octet-stream. As a result, the layer is not pulled.
Solution
You can use either of the following methods to solve this problem:
