On this page
Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ Best Practices/ Container/ Configuring the /etc/hosts File of a Pod Using hostAliases
Application Scenarios
If DNS or other related settings are inappropriate, you can use hostAliases to overwrite the resolution of the hostname at the pod level when adding entries to the /etc/hosts file of the pod.
  1. Use kubectl to connect to the cluster.
  2. Create the hostaliases-pod.yaml file.
    vi hostaliases-pod.yaml
    The field in bold in the YAML file indicates the image name and tag. You can replace the example value as required.
    apiVersion: v1
    kind: Pod
      hostAliases:
      - ip: 127.0.0.1
        hostnames:
        - foo.local
        - bar.local
      - ip: 10.1.2.3
        hostnames:
        - foo.remote
        - bar.remote
      containers:
        - name: cat-hosts
          image: tomcat:9-jre11-slim
          lifecycle:
            postStart:
              exec:
                command:
                  - cat
                  - /etc/hosts
      imagePullSecrets:
        - name: default-secret
    Table 1 pod field description
    Mandatory
    apiVersion
    Yes
    API version number
    kind
    Yes
    Type of the object to be created
    metadata
    Yes
    Metadata definition of a resource object
    name
    Yes
    Name of a pod
    spec
    Yes
    Detailed description of the pod. For details, see Table 2.
    Table 2 spec field description
    Mandatory
    hostAliases
    Yes
    Host alias
    containers
    Yes
    For details, see Table 3.
    Table 3 containers field description
    Mandatory
    name
    Yes
    Container name
    Yes
    Container image name
    lifecycle
    No
    Lifecycle
  3. Create a pod.
    kubectl create -f hostaliases-pod.yaml
    If information similar to the following is displayed, the pod is created.
    pod/hostaliases-pod created
  4. Query the pod status.
    kubectl get pod hostaliases-pod
    If the pod is in the Running state, the pod is successfully created.
    NAME                  READY          STATUS       RESTARTS      AGE
    hostaliases-pod       1/1            Running      0             16m
  5. Check whether the hostAliases functions properly.
    docker ps |grep hostaliases-pod
    docker exec -ti Container ID /bin/sh
