Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ Network/ Ingresses/ LoadBalancer Ingresses/ Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress
Dedicated load balancer ingresses support custom header forwarding policies. You can configure different header key-value pairs to determine the backend Service to which data is forwarded.
A cluster meeting the following requirements is available:
  • v1.23: v1.23.16-r0 or later
  • v1.25: v1.25.11-r0 or later
  • v1.27: v1.27.8-r0 or later
  • v1.28: v1.28.6-r0 or later
  • v1.29: v1.29.2-r0 or later
Using kubectl
An example YAML file of an ingress created using an existing load balancer is as follows:
kind: Ingress
  namespace: default
  annotations:
    kubernetes.io/elb.port: '80'
    kubernetes.io/elb.id: 08eab934-1636-4d90-a4cd-cb3fa4330411
    kubernetes.io/elb.class: performance  # A dedicated load balancer is required.
    # Path /a can be accessed only through Header key1=value1 or key1=value2. The accessed Service is svc-a:80.
    kubernetes.io/elb.headers.svc-a: |
          "key": "key1",
          "values": [
              "value1",
              "value2"
    # Path /b can be accessed only through Header key2=value1 or key2=value2. The accessed Service is svc-b:81.
    kubernetes.io/elb.headers.svc-b: |
          "key": "key2",
          "values": [
              "value1",
              "value2"
  rules:
    - host: ''
      http:
        paths:
          - path: /a
            backend:
              service:
                port:
                  number: 80
            property:
          - path: /b
            backend:
              service:
                port:
                  number: 81
            property:
  ingressClassName: cce
Table 1 Annotations for configuring a custom header forwarding policy
Type
kubernetes.io/elb.headers.${svc_name}
String
Custom header of the Service associated with an ingress. ${svc_name} is the Service name.
Format: a JSON string, for example, {"key": "test", "values": ["value1", "value2"]}
  • key/value indicates the key-value pair of the custom header. A maximum of eight values can be configured.
    Enter 1 to 40 characters for a key. Only letters, digits, hyphens (-), and underscores (_) are allowed.
    Enter 1 to 128 characters for a value. Asterisks (*) and question marks (?) are allowed, but spaces and double quotation marks are not allowed. An asterisk can match zero or more characters, and a question mark can match one character.
  • Either a custom header or grayscale release can be configured.
  • Enter 1 to 51 characters for ${svc_name}.
