Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Ingress
You can add IP addresses to a trustlist or blocklist to control access to a listener of a LoadBalancer ingress.
- Trustlist: Only the IP addresses in the list can access the listener.
- Blocklist: The IP addresses in the list are not allowed to access the listener.
- A Kubernetes cluster is available and the cluster version meets the following requirements:
- v1.23: v1.23.12-r0 or later
- v1.25: v1.25.7-r0 or later
- v1.27: v1.27.4-r0 or later
- v1.28: v1.28.2-r0 or later
- Other clusters of later versions
- An IP address group has been created on the ELB console. For details, see .
Using the CCE Console
- Choose Services & Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
- Configure access control parameters for the ingress.
- Inherit ELB Configurations: CCE does not modify the existing access control configurations on the ELB console.
- Allow all IP addresses: No access control is configured.
- Trustlist: Only the selected IP address group can access the load balancer.
- Blocklist: The selected IP address group cannot access the load balancer.
For details about how to configure other parameters, see Creating a LoadBalancer Ingress on the Console.
- Click OK.
Using kubectl
apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.id: <your_elb_id> # Load balancer ID. Replace it with the actual value. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.port: '80' # External port of the load balancer listener kubernetes.io/elb.acl-id: <your_acl_id> # ID of an IP address group for accessing a load balancer kubernetes.io/elb.acl-status: 'on' # Enable access control. kubernetes.io/elb.acl-type: 'white' # Trustlist for access control spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with the name of your target Service. port: number: 8080 # Replace 8080 with the port number of your target Service. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce
Parameter |
Type |
Description |
kubernetes.io/elb.acl-id |
String |
kubernetes.io/elb.acl-status |
String |
This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
kubernetes.io/elb.acl-type |
String |
