Heterogeneous Resources
GPU Settings
GPU Driver
  • Default Cluster Driver: specifies the default GPU driver version used by the GPU nodes in a cluster. To use a custom driver, enter the download link of the NVIDIA driver.
  • Custom Node Pool Driver: If you do not want all GPU nodes in a cluster to use the same driver, CCE allows you to install a different GPU driver for each node pool. After you customize a GPU driver for a node pool, nodes in the node pool will preferentially use the custom driver. Nodes for which no driver is specified will use the cluster's default driver.
    • The system installs the driver of the version specified for the node pool. The driver applies only to new nodes in the node pool.
    • After the driver version of new nodes is updated, you need to restart the nodes for the update to take effect. The driver version can be updated only for new nodes.
