Enabling Overload Control for a Cluster
After overload control is enabled, the number of simultaneous requests is dynamically regulated according to the resource pressure on the master nodes. This ensures that both the nodes and the cluster remain accessible.
Notes and Constraints
The cluster version must be 1.23 or later.
Method 1: Enabling it when creating a cluster
When creating a cluster of v1.23 or later, you can enable overload control during the cluster creation.
Method 2: Enabling it in an existing cluster
  1. Log in to the CCE console and click the name of an existing cluster whose version is v1.23 or later.
  2. On the Overview page, check the master node information. If overload control is not enabled, a message will be displayed. You can click Enable to enable the function.
Overload Monitoring
  2. On the Overview page, check the master node information. The overload level metric will be displayed.
    The overload levels are as follows:
    • Circuit breaking: Rejects all external traffic.
    • Severe overload: Rejects 75% external traffic.
    • Moderate overload: Rejects 50% external traffic.
    • Slight overload: Rejects 25% external traffic.
    • Normal: Does not reject external traffic.
Disabling Cluster Overload Control
  2. In the navigation pane, choose Settings.
  3. On the Cluster Access tab page, disable overload control.
  4. Click OK.
