Help Center/
Cloud Container Engine/
User Guide (Paris Regions)/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
Internal Error
Internal Error
Check Items
This check item is not typical and implies that an internal error was found during the pre-upgrade check.
Solution
Perform the pre-upgrade check again.
If it fails again, submit a service ticket to contact technical support.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
