CCE Container Storage (Everest)
Introduction
Everest is a cloud native container storage system, which enables clusters of Kubernetes v1.15.6 or later to access cloud storage services through the CSI.
Everest is a system resource add-on. It is installed by default when a cluster of Kubernetes v1.15 or later is created.
Notes and Constraints
- If your cluster is upgraded from v1.13 to v1.15, storage-driver will be replaced by Everest (v1.1.6 or later) for container storage. The takeover does not affect the original storage functions.
- In version 1.2.0 of the Everest add-on, key authentication is optimized when OBS is used. After the Everest add-on is upgraded from a version earlier than 1.2.0, restart all workloads that use OBS in the cluster. Otherwise, workloads may not be able to use OBS.
- By default, this add-on is installed in clusters of v1.15 and later. For clusters of v1.13 and earlier, the storage-driver add-on is installed by default.
Installing the Add-on
This add-on has been installed by default. If it is uninstalled due to some reasons, you can reinstall it by performing the following steps:
- Log in to the CCE console and click the cluster name to access the cluster console. Click Add-ons in the navigation pane, locate CCE Container Storage (Everest) on the right, and click Install.
- On the Install Add-on page, configure the specifications.
Table 1 Add-on configuration Parameter
Pods
Number of pods for the add-on.
High availability is not possible with a single pod. If an error occurs on the node where the add-on instance runs, the add-on will fail.
The Everest add-on contains the Everest-csi-controller and everest-csi-driver components. For details, see Components.
The add-on component specifications can be customized based on your requirements. Retain the default requested CPU and memory values of the add-on components. The limit values can be adjusted based on the number of cluster nodes and PVCs. For details about the configuration suggestions, see Table 2.
In non-typical scenarios, the formulas for estimating the limit values are as follows:
- everest-csi-controller
- CPU limit: 250m for 200 or fewer nodes, 350m for 1000 nodes, and 500m for 2000 nodes
- Memory limit = (200 Mi + Number of nodes x 1 Mi + Number of PVCs x 0.2 Mi) x 1.2
- everest-csi-driver
- CPU limit: 300m for 200 or fewer nodes, 500m for 1000 nodes, and 800m for 2000 nodes
- Memory limit: 300 Mi for 200 or fewer nodes, 600 Mi for 1000 nodes, and 900 Mi for 2000 nodes
Table 2 Recommended configuration limits in typical scenarios Configuration Scenario
everest-csi-driver
Nodes
PVs/PVCs
Add-on Instances
vCPUs (Limit = Requested)
Memory (Limit = Requested)
50
1000
2
250m
600 MiB
300m
300 MiB
200
1000
2
250m
1 GiB
300m
300 MiB
1000
1000
2
350m
2 GiB
500m
600 MiB
1000
5000
2
450m
3 GiB
500m
600 MiB
2000
5000
2
550m
4 GiB
800m
900 MiB
2000
10000
2
650m
5 GiB
800m
900 MiB
- Configure the add-on parameters.
Table 3 Everest parameters Parameter
csi_attacher_worker_threads
Number of worker nodes that can be concurrently processed by Everest for attaching EVS volumes. The default value is 60.
csi_attacher_detach_worker_threads
Number of worker nodes that can be concurrently processed by Everest for detaching EVS volumes. The default value is 60.
volume_attaching_flow_ctrl
Maximum number of EVS volumes that can be attached by the Everest add-on within 1 minute. The default value is 0, indicating that the performance of attaching EVS volumes is determined by the underlying storage resources.
cluster_id
Cluster ID
default_vpc_id
ID of the VPC to which the cluster belongs
disable_auto_mount_secret
Whether the default AK/SK can be used when an object bucket or parallel file system is mounted. The default value is false.
enable_node_attacher
Whether to enable the attacher on the agent to process the VolumeAttachment.
flow_control
This field is left blank by default. You do not need to configure this parameter.
number_of_reserved_disks
Number of disks on the node reserved for custom use. This parameter is supported when the add-on version is 2.3.11 or later.
Assume that a maximum of 20 EVS disks can be attached to a node, and the value of this parameter is set to 6. Then 14 (20-6) disks can be attached to this node when the system schedules the EVS disk attachment workloads. The reserved six disks include one system disk and one data disk that has been attached to the node. You can attach four EVS disks to this node as additional data disks or raw disks for a local storage pool.
over_subscription
Overcommitment ratio of the local storage pool (local_storage). The default value is 80. If the size of the local storage pool is 100 GB, it can be overcommitted to 180 GB.
project_id
ID of the project to which a cluster belongs
In Everest 1.2.26 or later, the performance of attaching a large number of EVS volumes has been optimized. The following parameters can be configured:- csi_attacher_worker_threads
- csi_attacher_detach_worker_threads
- volume_attaching_flow_ctrl
The preceding parameters are associated with each other and are constrained by the underlying storage resources in the region where the cluster is located. To attach a large number of volumes (more than 500 EVS volumes per minute), contact administrator and configure the parameters under their guidance to prevent the Everest add-on from running abnormally due to improper parameter settings.
- Configure scheduling policies for the add-on.
- Scheduling policies do not take effect on add-on instances of the DaemonSet type.
- When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on cannot run.
Table 4 Configurations for add-on scheduling Parameter
Multi AZ
- Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to that AZ.
- Equivalent mode: Deployment pods of the add-on are evenly scheduled to the nodes in the cluster in each AZ. If a new AZ is added, you are advised to increase add-on pods for cross-AZ HA deployment. With the Equivalent multi-AZ deployment, the difference between the number of add-on pods in different AZs will be less than or equal to 1. If resources in one of the AZs are insufficient, pods cannot be scheduled to that AZ.
- Required: Deployment pods of the add-on will be forcibly scheduled to nodes in different AZs. If there are fewer AZs than pods, the extra pods will fail to run.
Node Affinity
- Not configured: Node affinity is disabled for the add-on.
- Node Affinity: Specify the nodes where the add-on is deployed. If you do not specify the nodes, the add-on will be randomly scheduled based on the default cluster scheduling policy.
- Specified Node Pool Scheduling: Specify the node pool where the add-on is deployed. If you do not specify the node pool, the add-on will be randomly scheduled based on the default cluster scheduling policy.
- Custom Policies: Enter the labels of the nodes where the add-on is to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on will be randomly scheduled based on the default cluster scheduling policy.
Toleration
Using both taints and tolerations allows (not forcibly) the add-on Deployment to be scheduled to a node with the matching taints, and controls the Deployment eviction policies after the node where the Deployment is located is tainted.
The add-on adds the default tolerance policy for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints, respectively. The tolerance time window is 60s.
For details, see Configuring Tolerance Policies.
- Click Install.
Components
Component |
Description |
Resource Type |
everest-csi-controller |
Used to create, delete, snapshot, expand, attach, and detach storage volumes. If the cluster version is 1.19 or later and the add-on version is 1.2.x, the pod of the everest-csi-controller component also has an everest-localvolume-manager container by default. This container manages the creation of LVM storage pools and local PVs on the node. |
Deployment |
everest-csi-driver |
Used to mount and unmount PVs and resize file systems. If the add-on version is 1.2.x and the region where the cluster is located supports node-attacher, the pod of the everest-csi-driver component also contains an everest-node-attacher container. This container is responsible for distributed EVS attaching. This configuration item is available in some regions. |
DaemonSet |
