Configuring Network Policies to Restrict Pod Access
Network policies are designed by Kubernetes to restrict pod access. It is equivalent to a firewall at the application layer to enhance network security. The capabilities supported by network policies depend on the capabilities of the network add-ons of the cluster.
By default, if a namespace does not have any policy, pods in the namespace accept traffic from any source and send traffic to any destination.
Network policies are classified into the following types:
  • namespaceSelector: selects particular namespaces for which all pods should be allowed as ingress sources or egress destinations.
  • podSelector: selects particular pods in the same namespace as the network policy which should be allowed as ingress sources or egress destinations.
  • ipBlock: selects particular IP blocks to allow as ingress sources or egress destinations. (Only egress rules support IP blocks.)
Notes and Constraints
  • Only clusters that use the tunnel network model support network policies. Network policies are classified into the following types:
    • Ingress: All versions support this type.
    • Egress: Only the following OSs and cluster versions support egress rules.
      OS
      Cluster Version
      Verified Kernel Version
      CentOS
      v1.23 or later
      3.10.0-1062.18.1.el7.x86_64
      3.10.0-1127.19.1.el7.x86_64
      3.10.0-1160.25.1.el7.x86_64
      EulerOS 2.5
      v1.23 or later
      3.10.0-862.14.1.5.h591.eulerosv2r7.x86_64
      3.10.0-862.14.1.5.h687.eulerosv2r7.x86_64
      EulerOS 2.9
      v1.23 or later
      4.18.0-147.5.1.6.h541.eulerosv2r9.x86_64
      4.18.0-147.5.1.6.h766.eulerosv2r9.x86_64
      4.18.0-147.5.1.6.h998.eulerosv2r9.x86_64
      4.18.0-147.5.1.6.h1305.eulerosv2r9.x86_64
  • Network isolation is not supported for IPv6 addresses.
  • If upgrade to a cluster version that supports egress rules is performed in in-place mode, you cannot use egress rules because the node OS is not upgraded. In this case, reset the node.
Using Ingress Rules
  • Using podSelector to specify the access scope
    kind: NetworkPolicy
      namespace: default
      podSelector:                  # The rule takes effect for pods with the role=db label.
        matchLabels:
          role: db
      ingress:                      # This is an ingress rule.
        - podSelector:              # Only traffic from the pods with the "role=frontend" label is allowed.
            matchLabels:
              role: frontend
        ports:                      # Only TCP can be used to access port 6379.
        - protocol: TCP
          port: 6379
    The following figure shows how podSelector works.
    Figure 1 podSelector
  • Using namespaceSelector to specify the access scope
    kind: NetworkPolicy
        matchLabels:
          role: db
        - namespaceSelector:        # Only traffic from the pods in the namespace with the "project=myproject" label is allowed.
            matchLabels:
              project: myproject
        - protocol: TCP
          port: 6379
    The following figure shows how namespaceSelector works.
    Figure 2 namespaceSelector
Using Egress Rules
Egress supports not only podSelector and namespaceSelector, but also ipBlock.
Only clusters of version 1.23 or later support Egress rules. Only nodes running EulerOS 2.5, EulerOS 2.9, or CentOS 7.X are supported.
kind: NetworkPolicy
  namespace: default
  policyTypes:                  # Must be specified for an egress rule.
    - Egress
    matchLabels:
      role: db
  egress:                       # Egress rule
  - to:
    - ipBlock:
        cidr: 172.16.0.16/16    # Allow access to this CIDR block.
        except:
        - 172.16.0.40/32        # This CIDR block cannot be accessed. This value must fall within the range specified by cidr.
The following figure shows how ipBlock works.
Figure 3 ipBlock
You can define ingress and egress in the same rule.
kind: NetworkPolicy
  namespace: default
  policyTypes:
  - Ingress
  - Egress
    matchLabels:
      role: db
        matchLabels:
          role: frontend
    - protocol: TCP
      port: 6379
  - to:
    - podSelector:              # Only pods with the role=web label can be accessed.
        matchLabels:
          role: web
The following figure shows how to use ingress and egress together.
Figure 4 Using both ingress and egress
Creating a Network Policy on the Console
  2. Choose Policies in the navigation pane, click the Network Policies tab, and click Create Network Policy in the upper right corner.
    • Policy Name: Specify a network policy name.
    • Namespace: Select a namespace in which the network policy is applied.
    • Selector: Enter a label, select the pod to be associated, and click Add. You can also click Reference Workload Label to use the label of an existing workload.
    • Inbound Rule: Click to add an inbound rule. For details about parameter settings, see Table 1.
      Table 1 Adding an inbound rule
      Protocol & Port
      Select the protocol type and port. Currently, TCP and UDP are supported.
      Source Namespace
      Select a namespace whose objects can be accessed. If this parameter is not specified, the object belongs to the same namespace as the current policy.
      Source Pod Label
      Allow accessing the pods with this label. If this parameter is not specified, all pods in the namespace can be accessed.
  3. Click OK.
