Help Center/
Cloud Backup and Recovery/
User Guide (Paris)/
FAQs/
Capacity/
Why Does the Used Capacity of a Vault Change Only Slightly After I Deleted Unwanted Backups?
Updated on 2025-11-24 GMT+08:00
Symptoms
After unwanted backups are deleted from the vault, the used capacity of the vault decreases by only 1 GB to 2 GB.
Possible Causes
The backup mechanism of CBR:
- By default, CBR performs a full backup for a resource for the first time and backs up all used data blocks. Subsequent backups are incremental. An incremental backup backs up only the data blocks changed since the last backup.
- Each incremental backup is a virtual full backup. Correlated data blocks are indexed by using pointers.
- When you delete a backup, no matter manually or automatically, only data blocks that are not referenced by other backups will be deleted.
Figure 1 Backup mechanism
Parent topic: Capacity
