Help Center/ Cloud Backup and Recovery/ User Guide (Paris)/ FAQs/ Restoration/ Can a Disk Be Restored Using Its Backups After Its Capacity Is Expanded?
Updated on 2025-11-24 GMT+08:00
Yes. After restoration, the capacity of the expanded disk goes back to the original capacity before expansion.
If you want to use the capacity added to the disk, you need to attach the restored disk to a server, log in to the server, and then manually modify the file system configuration.
For details, see section "Disk Capacity Expansion" in the Elastic Volume Service User Guide.
