Help Center/
Cloud Backup and Recovery/
User Guide (Paris)/
FAQs/
Backup/
Does CBR Support Cross-Region Backup?
Updated on 2025-11-24 GMT+08:00
You can replicate backups to a destination region and create images in the destination region using the generated replicas.
You can replicate backups in either of the following methods on the CBR console:
- Select a backup from the backup list and manually replicate it.
- Select a backup vault and manually replicate it. Alternatively, you can configure a replication policy to periodically replicate backups that have not been replicated or failed to be replicated to the destination region.
Parent topic: Backup
