On this page
Show all
Help Center/ Cloud Backup and Recovery/ User Guide (Paris)/ Restoring Data/ Creating a File System from an SFS Turbo Backup
Updated on 2024-03-25 GMT+08:00
In case of a virus attack, accidental deletion, or software or hardware fault, you can use an SFS Turbo file system backup to create a new file system. Once created, data on the new file system is the same as that in the backup.
  1. Log in to the CBR console.
    2. Click in the upper left corner and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery. Select a backup type from the left navigation pane.
  2. Click the Backups tab and locate the desired backup. For details, see Viewing a Backup.
  3. Click Create File System in the Operation column of the backup. The button is available only when the backup status is Available.
  4. Configure the file system parameters.
    • You can learn about the parameter descriptions in table "Parameter description" under "Creating an SFS Turbo File System" in "Create a File System" of the Scalable File Service User Guide.
  5. Click Create Now.
  6. Go back to the file system list and check whether the file system is successfully created.
    You will see the file system status change as follows: Creating, Available, Restoring, Available. You may not notice the Restoring status because Instant Restore is supported and the restoration speed is very fast. After the file system status has changed from Creating to Available, the file system is successfully created. After the status has changed from Restoring to Available, backup data has been successfully restored to the created file system.
